SCT x4 Use and troubleshooting
Started by FoMoCoSHO, August 20, 2014, 12:38:39 PM
tmcphail
The D loss is real high through the AWD system ford uses. That % isn't inaccurate.
Take care,
Mr. Torrie R. McPhail - Owner
Unleashed Tuning Ford/GM/DCX SCT Custom Calibrator
EcuTek Nissan R35 GTR Custom Tuner
HPTuners Custom Tuner / Dealer
Ok, so working backwards with stock numbers, Torque, Dash Command, and 1/4 mile times, my crank power calculations are....
476 TQ
443 HP
Reasonable?
Corrected for DERP!
Torrie, I had my Reische 170 installed yesterday, do I need a tweak?
tmcphail
Take care,
MDesign Performance
Quote from: FoMoCoSHO on September 06, 2014, 10:49:19 PM
Do these kits have a low level warning built in?
Just for future reference, you can use a low level float switch and wire it up to an LED to retain this feature using any container. They're pretty inexpensive, below is an example. Maybe Torrie can start stocking these or add them to the meth kit.
http://m.ebay.com/itm/261476363116?nav=SEARCH
2011 MKS EcoBoost: MDesign Carbon Cold Air Intake; SP-534 Plugs; Power Stop C/S Rotors
sales@mdesignperformance.com
www.mdesignperformance.com
www.facebook.com/MDesignPerformance
tmcphail
I always use the factory washer reservoir that way you can retain the OEM low level system. That is unless you want to mount a huge reservoir in the trunk.
Take care,
tmcphail
No, just email me and I will handle it
Take care,
So my device needs updated apparently but it told me I need to return to stock first?
Is that true?
Do I need to put the 2 bar back in or can I do this process without starting the car?
AJP turbo
Quote from: FoMoCoSHO on March 16, 2015, 11:52:57 PM
Is that true?
U don't have to put the 2 bar back in but don't start it...it's not essential to return to stock but highly recommended per sct ....if ur update fails there is potential u will not be able to recover the exact stock calibration that was programmed to ur car...u can always get a stock equivalent calibration but technically that's not the same as what ur stock tune was...I've updated mine without returning to stock because I figure I'll never need it..just a risk I guess
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
Hi Torrie, couple questions...
On the x4 knock pid is a negative number adding timing and positive pulling?
Also for us E guys, what is the minimum rail pressure you are comfortable with?
tmcphail
#102
Correct. I don't like to see it below 1500PSI
Take care,
f8tlSHO
Quote from: tmcphail on October 24, 2015, 05:02:22 PM
Correct. I don't like to see it below 1000PSI
Earlier in this post you posted 1500psi, pretty sure it was for the same thing.
Sent from my iPhone
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
tmcphail
Take care,
