I switched back to my stock intake and went to track. No change in time but IA temps were 20/30 deg cooler sitting in staging. Put Airaid back in tho, Just not the same without the massive noise fluff lol. I also cut the bottom corner near fender opening off Airaid box, Pulled both rubber gaskets off hood, and one off top of wiper cowl so air goes thru underhood. cut back of grille out so now you can see air cleaner thru grill, and I left off that massive shield under motor. stays alot cooler now. Need all I can get in Florida. I think I'm going to cut a slot in core support cover and bend a piece of metal at a 90 so I can block the grille opening back off when it rains like hell down here.
