K&N filter, drop in or whole set up?
Started by 2010SHOtime, March 11, 2014, 12:15:06 AM
I ran better with my stock intake + K@N drop in than the typhoon.
Night Hawk
Quote from: Livernois Motorsports on March 12, 2014, 08:25:57 PM
We recommend our Windstorm CAI for the Eco-boost platforms gain up to 10 additional horsepower! We just received a new shipment in. Get yours today!
  Any pics bud?
2017 Fusion Sport
GFB DivValve/165* Thermo
K&N Panel/CFM Breather
Ult Perf Int Garrett Core/MKZ oil cooler
FMS 70mm TB/ NGK .026/LMS V6 93
Quote from: FoMoCoSHO on April 10, 2014, 09:20:09 PM
I'm not at all surprised... Mike had the same experience with AirAid.
I have an AirAid and even though I will more than likely end up with the Fastlane CIA it's worth noting that the top 3 SHO members  in the 1/4  all run AirAid  .... just a thought
bamsho
Well, here are my personnal results with CAI and stock air box.  Ran car at BSD test and tune this past sat.  Weather was nice and track conditions were good.  Ran first pass with K&N CAI and did 13.47 @ 102. Took car back to pits, swapped CAI for stock box and K&N panel filter.  Went back and car ran 13.32@103.  I couldn't believe it, but there it was, ran another run and ran 13.39, also realized I still have TRAC Control still on.  Car had LMS Stage4+ in when I did those runs.  I've been reading the posts about this debate and wanted to see for myself, and wife said wow too.
Quote from: SwampRat on April 11, 2014, 01:55:31 AM
With meth I think... overcomes a lot with the added HP.
IMHO...The most valid testing as far as performance is comparison of just the intake system as a variable.
black99lightning
Quote from: bamsho on April 14, 2014, 11:47:38 AM
Were cooldowns the same?  I maybe doing the same thing soon.
2013 Esport 13.44 @ 103.6
1999 Lightning 12.44 @ 108.4
2012 GT500 10.96 @ 130.6
2006 GTO 12.83 @ 107.8
2013 CTSV coupe 11.79 @ 119.7
bamsho
black99lightning
Quote from: bamsho on April 14, 2014, 01:20:18 PM
Yes, 15-20 minutes.
Cool.  I may have a Typhoon and Airade for sale soon.
I figure with the number of cai's that are gonna end up for sale, mine will end up being a garage decoration. FML.
SHODYOU
I read the description on their website as it says something about Windstorm in one of their packages...
no image but it says something about a new tube and an airbox, not an open filter
Hmmmm
Quote from: FoMoCoSHO on March 12, 2014, 08:28:26 PM
Heads up!
Livernois Windstorm had no results on google.
painterpatt
I have the Airaid on my Flex, sounds cool but the rubber gasket is a joke, not even close to the bottom of hood. My intake air temp will climb from 100 to 155/60 just sitting in staging. seriously thinking about ditching it and modding stock airbox but with a non oiled filter. Turbos pull WAY more air thru filter and will suck oil out of it. I thought I read somewhere about Ford voiding turbo warranty because oil gums up turbos?
Koolaid drinkin, Flex drivin !!
Take a look at the Fastlane cai thread.
I have "stumbled" upon some info as to why the OEM performs better.
bamsho
Here is the modified air box I did.  Someone else did it too on his MKS, used PVC pipe, but I used 3" intake flex pipe.  It was very tight under the left front head light assembly, that's why I used the flex pipe.  Going to order a Frogzskin breathable filter to help keep out bugs and other big debris.  Frogzskin is used on newer snowmobiles too keep out snow and snowdust.
Quote from: FoMoCoSHO on April 14, 2014, 09:24:02 PM
FMCS... Could you link the post?... There are 3 threads about the Fastlane CAI. TIA
