3 Bar sensor
Started by SoCalSHO, August 31, 2013, 01:38:49 PM
The one before the throttle body is the 3 bar sensor, the one on the manifold is a 2 bar.
JMR76
Quote from: 4DRHTRD on September 30, 2013, 09:07:48 PM
Thanks!!!
2013 SHO - PP/ GH Intercooler / 170*TS / Cold .026 plugs / MSD Coils / Corsa cat-back / PPE Catted Downpipes / Xtreme-DI XDI-EO HPFP / E 30+ / Gear Head Tuned.
Boggus
This is what I have:
3bar sensor
2013 unleashed SHO PP
JMR76
Quote from: Boggus on September 30, 2013, 09:17:21 PM
3bar sensor
Yeah, that's the one they sent me.  Thanks!
EcoBrick Bob
In my Flex, that sensor which I purchased from Torrie to put on top of the intake, is identical to the one on the side of the pipe just in front of the TB.
Naples, FL & Clear Lake, IA
Quote from: EcoBrick Bob on September 30, 2013, 10:43:21 PM
Correct the tip sensor is a 3 bar
Sent from my SCH-I545 using Tapatalk 4
Courier6
3bar sensor
So why is it that there is no 2nd mounting bolt? No hole drilled for it for that matter, my car is exactly the same.
2013 Tri-White PP, PPE downpipes, Corsa, Air Raid CAI, H&R Springs, 170 deg thermo, Livernois Dyno Tune 365 AWHP 407 AWTQ. Best 1/4 mile 12.580
My 2010 has both bolts (1 on either side of the sensor).
I believe in 2011, the bean counters hired by FMC got involved, and began figuring out how to reduce costs (.01 here, another .01 over there, etc,) and dediced to lop off one bolt from that model year and onward.
No real reason other than that.
If they save the cost of the bolt, the cost of drilling/tapping that 2nd hole, as well as the time it takes to fasten/screw that bolt down, or the time to drill/tap out the hole to, etc. etc.
You multiply that, by however many 3.5 Eco motors produced....
And you save a lot of money.
EcoBrick Bob
That's just like our 2010 EB Torque Converters... They have 4 bolts.... The 2011 on have 3, just like the non-EB 3.5 engine.
Boggus
#54
So 2013's are faster because they weigh less?  1 screw/ bolt at a time
Kind of throws a whole monkey wrench into the theory of any 1st model run/year of any given car, is somehow taboo, or destined to be worse than any subsequent, following years produced.
Makes me almost happy to own the 2010 that I do.
Especially if those dasterdly bean counters get involved and start whittling away various parts all throughout the car, with the sole purpose in mind of simply cost cutting measures.
Boggus
After your turbo install, I'm sure you will have some missing bolts also !!!!!!
J/K
EcoBrick Bob
FYI... Several of us... who want to remain secret... (including me...) are going to 4 bar sensors... Performance gain expected... UNBELIEVEABLE!!!!!
Makes your stock turbos feel like babes again!!!!
SoCalSHO
Quote from: EcoBrick Bob on October 23, 2013, 09:52:49 PM
Riiiight. I am going right to 5 bar. Shhhhhhh.
Robert
2010 Met White
GH tuned, 3 Bar, upgraded turbos, 91 Oct
K&N drop-in or airaid, Corsa Cat-back
1/8 Mile 8.380@83.42MPH
Quote from: bpd1151 on October 22, 2013, 10:53:11 PM
I would rather have my awesome brakes than your extra sensor bolt. ;D
That being said, your ride is still awesome!
