3 Bar sensor
Started by SoCalSHO, August 31, 2013, 01:38:49 PM
05yellowgt
The f150's have a 3 bar map stock though correct?
2010 Ford Flex Limited w/Ecoboost- SOLD
2013 F150 FX4 Supercrew 6.5ft bed Ecoboost w/3.55
SoCalSHO
Robert
2010 Met White
GH tuned, 3 Bar, upgraded turbos, 91 Oct
K&N drop-in or airaid, Corsa Cat-back
1/8 Mile 8.380@83.42MPH
05yellowgt
Going by Rock Auto, this is what I was about to find.  Unfortunately the Ford part numbers didn't show up.
For 2013 F150
CX2420-MAP Sensor
application
FORD   ESCAPE   2013
FORD   F-150   (2012 - 2013)
FORD   FOCUS   2013
CX2401-Manifold MAP Sensor
application
FORD   F-150   (2011 - 2013)
For 2013 SHO
CX2228-MAP Sensor
application
FORD   FLEX   (2009 - 2013)
FORD   GT   (2005 - 2006)
FORD   MUSTANG   (2003 - 2004)
FORD   TAURUS   (2010 - 2013)
LINCOLN   MKS   (2010 - 2013)
LINCOLN   MKT   (2010 - 2013)
CX2231-Map Sensor
application
FORD   FLEX   (2010 - 2013)
SoCalSHO
That'S A Good Price, Free Shipping Too.
Robert
2010 Met White
EcoBrick Bob
If you're using Torrie's system, or Livernois - wouldn't it make sense to pay $25. more and get it from them if they are going to be tuning your vehicle?
Naples, FL & Clear Lake, IA
Quote from: EcoBrick Bob on September 25, 2013, 11:27:16 AM
Not in my opinion, get the part and use it. Torrie tuned my car when I bought it, it's a factory MAP sensor...
SoCalSHO
I Wouldn'T Think So. One Of Those Places Is Chrging $30 More Plus $33 Shipping. As Long As The Part Is, Or Modified As A 3 Bar Sensor, And I Can Save Money, That WorkS For Me. I Am Loyal To A Point. Now, That $60 Difference Allows Me To Buy A Lower Temp T-stat.
Robert
2010 Met White
I'd buy and stock these map sensors but I'd just have to mark them up as I can't get them even $5 cheaper so it makes sense for people to just go there and order them.
I'm glad I found the link for everyone.
SoCalSHO
Robert
2010 Met White
JMR76
Quote from: 4DRHTRD on September 25, 2013, 10:17:42 AM
I ordered AA5Z-9F479-B from this link, it's a 3 bar.
http://www.sarad.com/productinfo.aspx?p=180813
Does this fit any year SHO like the 2013?  The reason I ask this dumb question is because of the 2013 only having one screw to hold it in.  Not sure if this makes the insert or connection different than 2010-2012 models.
2013 SHO - PP/ GH Intercooler / 170*TS / Cold .026 plugs / MSD Coils / Corsa cat-back / PPE Catted Downpipes / Xtreme-DI XDI-EO HPFP / E 30+ / Gear Head Tuned.
Pretty sure it's the same for all, just takes 1 or 2 screws to hold it in :)
EDIT, I know it works - my intake manifold is from a 2013, my 2011 intake is in my garage. :)
Quote from: crash712us on September 23, 2013, 05:49:29 AM
What you find is the part no. Is for 2 bar MAP sensor on you 3 bar MAP sensor box. It's not a off the shelf part as stated before, these are modified parts.
Shoman I don't why you see the need to trump my info all the time, LMS is 3mi's from my home I know Dan Milen well enough to have direct contact with him. So I consider myself to have a little more knowledge then most, not making this a brag. It's just simple semantics, as always I try to keep my conversations friendly and factual. And I let people believe what that want believe. So let's just leave at that my friend. No good will done here by me by proving your misinformed.
Crash I had so much fun hanging with you at LMS TRACK DAY. I would NEVER try to TRUMP,DISK,OR OTHER WISE DOWN YOU!!!!!! Every thing you said about your car is a 100% correct, But there is a new revision of the METH KIT. In the old kit you had to pwr the #1 pin of MAP for the modified 2bar to work. (pic#1) that bpd install instruction tell you to do. I PAY $400 in LMS tech labor time to find out the NEW KIT  has a 3bar factory sensor and this (2nd pic) MAP control box w/red-green-&blk wires replaces 2bar pin#1 pwr in put. cutting that pwr wire and my car ran great. You can't do both either the new way or the old but not both!!!!
NO HARD FEELING's MY FRIEND, Or trumping you, except on the track and that's out of respect for how fast you are (I'M STILL DANCING).LOL
1st pic
2nd pic
Since we're talking about 3 bar maps sensors if anyone knows the intercept and slope for the 3 bar map sensor I could sure use it so I can tune my car :)
JMR76
#44
I'm still confused about the numbers or if they sent the wrong sensor.
I ordered one from here and the Motorcraft box it came in states what I ordered.  The box does show CX2231 and AA5Z-9F479-B but the box wasn't sealed and it looks look they stuck another sensor in there.  The sensor itself is AA5A-9F479-AB. The bottom is 5WK9 6848, the same as the first sensor before the throttle body.
How do I know if this is a 3 bar or not?
Thanks
