Unleashed 3 bar 93 octane tune
Started by f8tlSHO, June 20, 2015, 02:24:02 PM
Quote from: glock-coma on June 22, 2015, 10:02:15 PM
Edit. Damn you guys type FAST.
LOL, I hunt and peck about 6 words per minute.
Quote from: FoMoCoSHO on June 22, 2015, 10:07:22 PM
I'm 2 thumbs on a tablet right now.  I might as well be monkey punching this thing.
2010 RCM non PP
K&N panel filter with aux hose
RX OCC with CSS
sp534 @ 30
unleashed tune 12.90@106
f8tlSHO
Lol, I am on my phone 99.9% of the Time
Sent from my iPhone
2013 Non PP Unleashed 93 E20 3 Bar Tune, K&N drop in 12.491 @ 110.96 120's IAT
Now tuned by ajp...looking to go faster
E30 tune on14psi full weight including 2 child seats,race like a real street car.
12.433 @110.8 140's IAT; Mustang Dyno 332hp / 386tq
f8tlSHO
Quote from: glock-coma on June 22, 2015, 10:08:43 PM
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
Lol
Sent from my iPhone
It doesnt matter which tune file your using or if your reverting back to stock tune,the big question is where there any DTC codes set,and if so you have to clear them before you can revert back to a specific file tune,and check which codes were set if any.  Z
wasinger3000
It should not spin that much. If you can find some sand you can see if the rear wheels spin when you hard launch.
Try a light boosted launch and roll into the throttle once the car is moving.
A full on boosted launch has never been the most effective way for me.
13' GTCS, will be missed.
f8tlSHO
No idea, the light was steady on with my torrie tune... It's not now(stock)
Glock- how long have you had a unleashed tune? Any modifications made?
Sent from my iPhone
f8tlSHO
Quote from: wasinger3000 on June 22, 2015, 10:11:38 PM
It was definitely front wheel drive for the tire spinning. I would just floor it at 15mph and the front end went sideways without a launch
Sent from my iPhone
Quote from: ZSHO on June 22, 2015, 10:10:05 PM
The x4 clears all codes in the final step of the flash process.
Not sure if this is what your talking about.
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
Quote from: f8tlSHO on June 22, 2015, 10:12:27 PM
Sent from my iPhone
I've been Torrie tuned about 2 years, only a couple tune revisions due to high knock reading with winter gas.
No data logs yet.  Right now I'm running the original 2 bar tune Torrie sent me with 2 gallons of e85 per fill up.
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
f8tlSHO
Quote from: glock-coma on June 22, 2015, 10:20:05 PM
Sent from my iPhone
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
How much boost are you running?
Sent from my iPhone
Quote from: f8tlSHO on June 22, 2015, 10:26:33 PM
Sent from my iPhone
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
Sent from my iPhone
I usually see a max of 16.  But I'm sure that's spike. Not sure of sustained boost.
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
Quote from: glock-coma on June 22, 2015, 10:17:10 PM
2010 RCM non PP
RX OCC with CSS
sp534 @ 30
It should SHO exactly what codes were cleared before the flash,which should be beneficial,if it permits. Z
ElvenSho
I am at 11th revision for my torrie 93 tune and he still didnt tell me its enough. Got to get another one out. I didnt know that I needed to give the car time to relern things before logging. I did few logs in the same hour or two before and torrie never told me to wait. (He does not really say much in his emails lol) I also had him mess with my shift points a bit, i believe i have it set up at 5850rpm for 1st to 2nd and about 5900 for 2nd to 3rd shift, feels perfect now. I noticed that my car feels the best once i just load a new tune and after few days it does not feel as good, probably due to the learning process. I need to get this tune dialed in already so i can take it down the track ughh!
2011 Red Taurus SHO- H&R springs, plugs, t-stat, 3bar, LMS dps, tuned by Torrie
As many have said before, you have to let the tune settle in first, let the relearn process happen before you send a tune for revision.  Datalogging at any time is a good idea, but not really useful to send it in before the relearn happens.
Can't harp and nag on this enough either:  make sure your maintenance is up-to-date.  Running a tuned vehicle also ups your responsibilities factor.  Look at what bpd does, what SHOnUup (Rich) does.  You want the best, you gotta give the best.
