Always good to datalog and have the tuner look at it the first few times. Also to give you a comfort level with the tune & the car. Torrie will let you know if he sees something off that needs to be adjusted. One thing to keep an eye out for is the shifting. If it is hard enough to cause hop, you will need to have shift pressure dialed back, to under 200 psi I believe.
