Oil In The Intake Piping
Started by SoCalFlexin, April 15, 2015, 07:12:53 PM
SoCalFlexin
Quote from: SHOdded on April 28, 2015, 02:56:23 PM
Some progress at least!  In the meantime you can see if changing oil brands/filters/viscosities helps with the startup rattle at all.  Full synthetic seems to be called for.
Yep, that's how im looking at it. I'm going to change to a full synthetic this weekend and see if it helps. Thinking about trying out the new Pennzoil
2012 Titanium EB Flex White Platinum Metallic Tri-Coat
I know people don't like oil additives but mos2 does work and is cheap around 6 dollars for a can. Do your own research. Plenty of threads on bitog to start your search if interested.
AJP turbo
Quote from: SoCalFlexin on April 28, 2015, 03:03:18 PM
I'd have to look at it but I'm pretty sure it's not real synthetic...it's probably a group iii hydrocracked petroleum....not sure why this bugs me so much but I guess because it's a disservice to the true group IV /V synthetics such as amsoil redline and the top tier royal purple among others
SCT Dealer/Custom Calibrator
Specializing in 3.5 Ecoboost
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
SoCalFlexin
I just pick up the Flex and it is the dirtiest i have ever seen it. Also i noticed it seems to be running rough at idle, i know i haven't driven it in a week but i don't think i use to feel shaking in the steering wheel like this before, only at idle
Take a quick look-see if all piping is connected and fluid levels are ok (not overfilled)?  Could be idle relearn, but don't know for sure.  Maybe put up a pic of the service order to see what work they actually did?
You did have the 2 bar+stock tune when you turned it in for service?
SoCalFlexin
Quote from: SHOdded on April 28, 2015, 05:22:36 PM
Definitely no tune. I will give a look under the hood when i get off work
AJP turbo
They tend to idle a little rough after a reflash or a kam reset...not sure why...I wouldn't worry about it...drive it a few times and see what it does
Former:2014 PP SHO
405whp/520tq
Dyno
Tuning in progress
SoCalFlexin
ShoBoat
New turbo, at least there's that! I would hope they reset the adaptive learning after all that work. If not and you still find it idling and running weird you can follow this guys instructions on how to do it yourself. He is a ford tech.
https://m.youtube.com/watch?v=hZAsoqmqhdM
2012 Pearl White CTS-V Stock
SoCalFlexin
i drove the car around last night for a few hours, didn't see any improvement, same thing this morning so i brought it back to the dealer. I can feel the roughness of the idle all through the car at idle in gear and with the AC on its worse. I was told that they removed the sub frame to change the rear turbo, i wonder if they didn't put the sub frame in the correct spot if it would make the car feel like this
No smoke out the exhaust though?
SoCalFlexin
No smoke, they fix that problem but made another
wasinger3000
Damn. Just cannot win. Can you get someone to sit in the flex and hold it in gear with the ac running while you poke around and listen for any kind of vibration? Maybe take a rubber mallet and hit the sub frame a little.
13' GTCS, will be missed.
66 Galaxie
I wonder if the sub frame uses one time use stretch bolts and if so if the tech didn't replace them so they aren't actually tightened to spec and this is transferring  or creating vibration.
Forgot to ask, does it happen in drive and reverse or just drive?
SoCalFlexin
It vibrates in park but it gets worse when there is a load on the engine. Yes in drive and in reverse and when the AC compressor kicks on it get worse.
