- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: StealBlueSHO on April 17, 2019, 02:53:09 PM
EPP Hot Pipes installed.... Firestorm HPFP sold off... new XDI pump incoming tomorrow or Friday... off for GH turbos and EPP catted downpipe install on Saturday... pickup and dyno on Wednesday...
EPP Hotpipes install was OK at best... requires A LOT of adjustments to get them straight... this I believe is due to the this tab not being welded on in the correct place.. there is enough slop in the couplers to adjust them.. but still...
60% flow over stock or 35% more flow XDI HPFP? And what is it that you feel will be better for your set up to have the XDI pump instead of the Livernois HPFP?
