Xtreme DI HPFP for SHO
Started by StealBlueSho, March 24, 2017, 10:07:42 PM
bamsho
From what I have read, yes it needs a tune to run.
StealBlueSho
Quote from: bamsho on March 27, 2017, 04:16:45 PM
I'm gonna email LMS... if I have to have the LMS tune to run the HPFP, like I have stated, unless they BLOW AWAY my current tune... not worth the money..for my plans with this vehicle.
StealBlueSho
Rockstar04
HPTuners has a section for tuning the parameters of the HPFP, so I doubt its something super special ONLY Livernois can do. Knowing them they will refuse to give real specification on the pump though, so to properly tune for it you may have to disassemble it to get its volume.
2016 Explorer Sport - Bone Stock
StealBlueSho
Response from LMS..
Dave A (LivernoisMotorsports)
Mar 27, 15:42 COT
Michael, yes we are developing that hpfp pump, we do have a tune for that pump, if your other tuners can build a tune for the pump than you can buy pump alone and they can tune, I would check with them to make sure they can calibrate for the new pump, if you put the pump on the SHO, it will not run woth the factory calibration if you have to go into the dealer for service, Dave
Blackhawk
What is the deal with the confusion with extreme-DI and LMS.  I know I've seen a previous post from LMS staying they are developing their own and it is not the same as the RTR pumps.  What pump was LMS referring to when they said they are developing "that" pump.
StealBlueSho
Quote from: Blackhawk on March 27, 2017, 11:36:06 PM
I was unaware there was a previous discussion about it. LMS tends to rebrand stuff, had I known there was already a thread about that aspect I wouldn't have brought it up. However, the original intent of this thread was that extreme DI had listed the SHO pump as available...
Blackhawk
Not directing any ill will towards you, if the x-di pump was available like the website seemed to imply this is certainly worth posting.  Thanks for the leg work you've done.
mrhighcaliber
Quote from: StealBlueSho on March 28, 2017, 03:49:40 AM
I didn't know about an upgraded di pump solution until this thread. So thank you. I didn't even know that lms already had one available for the f-150.
Sent from my Nexus 6 using Tapatalk
Quote from: mrhighcaliber on March 28, 2017, 05:12:15 PM
http://www.hotrod.com/articles/direct-injection-mystery-solved-injectors-pumps-ecoboost-tensema16/ . Z
StealBlueSho
Extreme-DI was unable to provide pricing or flow rates yet as its too early... but I am on a list they will email when they have it. Good communication from those guys. I will update as soon as I found out.
I can vouch that Livernois is not rebranding these...they are created in house...eye witness here
StealBlueSho
Quote from: SHOnUup on March 29, 2017, 07:09:28 AM
Awesome!!! More options!! If you can't tell I'm really stoked about it!
There should be 2 pumps also...regular upgrade, and a severe duty upgrade.
Speculation on pricing is 1599 & 2399....that's just speculation, and could change as R&D unfolds more
StealBlueSho
#29
That's what Anthony told me as well. Good to hear the same from someone else.
