Not sure if it helps or not, but here is a log of my XSport in cold(er) temps. I'm not certain, but I assume the fuel system is the same as the SHO?
I also had the AJP boost regulator installed, so it would have helped minimize pressure drops during shifts.
Ambient: 8.6 F
IAT2: mid 50s at start of runs
Target Boost: 14.5 PSI
Note, since this log was taken, I've changed the regulator boost reference and moved down to 15.95 PSI springs, which helps with the pressure drops. We've not had any bitter cold since making these changes, but if it gets back down close to 0, I will log again for comparison.
