Quote from: AJP turbo on December 04, 2016, 12:13:48 PM
Have any data logs?
I dont think winter blend is as much of a problem as people think...maybe if you are on the ragged edge but I doubt your lms tune is
I agree.
Listen -- I've had on and off problems with my LMS tune since I bought it two and a half years ago. I think the tunes are excellent -- when it's warm and you have good traction. I honestly think the problem is one of these things:
#1 bent rims, cold tires, low air, or unbalanced tires setting off the traction control. What does your tire pressure look like? When was the last time you had your tires balanced? How bad was the wobble? Mine was pretty bad.
#2 Steering angle sensor issues - Since I had the car, my car would bust out a C1B00 DTC every once in a while. While I highly DOUBT that this is the case, its still different than a "healthy car". Perhaps its messing with the torque vectoring exposing a bug in the ECU under higher boost / RPM?
#3 The tune. I've had popping / hesitation on summer gas, winter gas, small blend of E85 gas, with octane booster, and with 89 / 91 / 93 octane gas. I had problems with the 91 2bar / 91 3 bar / 93 2 bar and 93 3 bar tunes with this hesitation. Version 8 - whatever it is now. It's fine while stock, just the tune is amplifying something.
When you think of what's changed -- you have to ask ATPturbo and LMS to be certain, but I think its only torque based and transmission line pressure (shift points too). Something just isn't happy with the car.
I am not bashing LMS. I think they provide excellent customer service. I also think my video blog pissed a few people off and they somewhat gave up on finding the root cause of my vehicle. That's neither here nor there, after I changed my front tires to the back, I've had very little problems with the car; so I'm just blaming it on that..
#4 I know there are a few tuning companies out there that have good results. Sabtaj has the unleashed tune, and he's had none of the problems I've had. Granted he runs different tires, rims, and is doing the whole E85 / meth / crazy tune route. He just showed me a video of him going head to head with a hellcat -- close race too
Good luck -- I hope I've helped you.
