- RotM Winner
- Elite Member
- Boosted
- Logged
1" hubcentric wheel spacers. I tried these out last year briefly and took them off and sent them back. My rear tires were rubbing on the 10'oclock position(rear bumper mount). Feeling determined to get these on I reordered a set and while I had my rear bumper off to install my new rear reinforcement bar, I got to some cutting. The tab there stick in the the fender area a bit....I trimmed some and cut some on both sides in the rear. I cut and trimmed around the mount, not eliminating it. It's not pretty but it gets the job done. Only way to see it is to look in my wheel well a tad...in which case no one will see it. I did not rub up front at full turn so no trimming up front.
I had a chance today to test fit the rears and go for a test drive, down the same bumpy crappy road. I rubbed once...compared to every single bump like last time. 90% done. I think I'll heat some of whats left up highlighted in red and push it in. Going for no rubbing at all. Almost there. Looks amazing though. One pic driverside no spacer, compared to passenger side with spacer.
My wheels are 20x9.
