Does this pipe look split?
Started by jbeez, August 08, 2017, 02:53:21 PM
jbeez
Pipe going down to the rear turbo on my '14 SHO....
Brad reviewed my log, says I have a boost leak, im around sea level and car is acting like 6k elevation. I was poking around and it looks like this pipe is split on the seam
2014 PP SHO Darkside Metallic
K&N Panel filter, 3bar map, AJPTurbo tune, Motorcraft SP542 @.28, MSD Coils, PPE Catted downpipes, EBP Hot pipes w/ tial BOV, Tracy Lewis catch can, 170 tstat, 93 octane pump gas
StealBlueSho
Hard to tell in that picture....is it really loose around the seam? Mine is tight.
It looks loose IMHO.!!  I think you can purchase a 1.5" To 2" Straight Turbo/Intercooler/Intake Piping Coupler Reducer Silicone Hose +T-bolts clamp. Z
$5.00
http://www.ebay.com/itm/1-5-2-3-PLY-STRAIGHT-TURBO-INTAKE-INTERCOOLER-PIPE-SILICONE-REDUCER-HOSE-BLACK-/400494635869?hash=item5d3f572b5d:g:CtAAAOSwMmBV4lJF&vxp=mtr
jbeez
theres no adjustment on the hard pipe to the flexy part, only thing down there I can tighten is that hose clamp, I should prob take this pipe off and inspect it if its not a huge PITA I may do that in a few minutes
jbeez
So, I took that pipe off, and IDK how much boost my lungs create, but that pipe isn't leaking when I close off the different ends and blow hard on it LOL
What other areas should I check for a boost leak besides the pipe with the two BOVs on it?  I guess I'll have an opportunity to make sure the connections are tight when I put this pipe back on
TopherSho
Quote from: StealBlueSho on August 08, 2017, 02:59:31 PM
Overclamped and cracked the plastic!?
In my opinion I'd drop a GoPro an record the sound.  It will whoosh like a mofo if there is aleak
Best 0-60 public road 4.35s
Here's your PIC!!    Notice any difference?. Z
jbeez
put everything back together, and my neighbor came over and listened as I brake boosted it, he couldn't hear any leaks, this was after I put it back together and tightened the clamps down.  I used a tiny 1/4" socket to tighten those so I don't think i went nuts torquing it down. I'll log again and see whats up now that everything is reconnected
Mine actually split on the rubber bit, I couldn't see it until I folder it and then there was a little cut in it. Took me 2 months to find it and the reason I came out with hot pipes.
Hot pipes from mike are never a bad idea and look nice.
Also check those bov's..a couple people here had them split....there is a leak somewhere...you can see wastegate duty sky rocket at high rpm in an attempt to maintain boost but boost still drops bad
Look at the orange rubber on the inside of blow off valves, they've been known to tear apart.
That hard plastic pipe looks kind split above the rubber part...the thick plastic ring
jbeez
that hard plastic ring, does that come off anyway besides breaking it? It looks like some sort of factory clamp, I can say that when I had the pipe off, I was able to push the factory hard plastic piping into and out of the rubber coupler slightly, but it still looked sealed
the factory BOVs weren't letting any air through when I did my small pressure test over here.  I'm going to see my guy tomorrow about some other car stuff, while im there i'll see if he can take a look. I couldn't easily get to the front turbo outlet either so maybe we can put it on the lift and look too
