Does this pipe look split?
Started by jbeez, August 08, 2017, 02:53:21 PM
You know what the fix is.... Come to the dark side... :P
Quote from: EcoPowerParts on August 08, 2017, 06:33:18 PM
......................Mike you mean something like this.  Z  :)
I found Pledge to do wonders on the HOTPIPES +BOV which works great on metal and more.  Z
You are a Master Jedi of the Clean, Z!
Quote from: SHOdded on August 08, 2017, 07:18:27 PM
-MANU your much to kind sir.  Z
Quote from: ZSHO on August 08, 2017, 07:05:17 PM
Show off
Quote from: jbeez on August 08, 2017, 04:52:12 PM
, I can say that when I had the pipe off, I was able to push the factory hard plastic piping into and out of the rubber coupler slightly, but it still looked sealed
I dont think it should move..and i know you said the turbo was replaced and thats why its oily but at that ring it looks oily and dust is sticking
Your wastegate duty can and will go to 100 when spooling and desires tip is higher than actual but you need to look at your log in your multigear pull at 5000 rpm and up...the wastegate duty takes off and boost drops....look at map. You should have no problem maintaining 14 psi at your elevation...you should only see map drop 10 kpa at most from 5k to 6k and yours drops 20 i think...look at 3rd gear not others
jbeez
CC still recovering from downpipes last week LOL
2014 PP SHO Darkside Metallic
K&N Panel filter, 3bar map, AJPTurbo tune, Motorcraft SP542 @.28, MSD Coils, PPE Catted downpipes, EBP Hot pipes w/ tial BOV, Tracy Lewis catch can, 170 tstat, 93 octane pump gas
jbeez
For any of you who had the oem pipes cause a boost leak, where did it fail? Is that coupler the most common spot?
Here is a member who had the same identical issue as your's and it's very common for the charge pipe to split there due to excessive heat which primarily is found by the rear/back of the engine.
The front turbo hose is another weak point vulnerable to the elements. Z
https://www.ecoboostperformanceforum.com/index.php/topic,7388.msg114337.html#msg114337
jbeez
Quote from: glock-coma on August 08, 2017, 04:40:05 PM
Look at the orange rubber on the inside of blow off valves, they've been known to tear apart.
Took off both BOVs, rings looked good, maybe the rear had some oil under it. Ill have to inspect it again tomorrow and get some good pics
jbeez
How can i safely clean the green seal on the bov? Can I take it off the bov and wipe it down with something? Can I test these factory BOVs somehow?
The seal is very(fragile)especially the orange/red Diaphragm/plunger which they DO NOT sell separately.
I would inspect for any rips or tears and clean it gently with a moist shop towel while avoiding any harsh chemicals and you should be fine. Z
jbeez
This is a bit maddening without the right tools to test. I just took more pipes off, checked connections.
Is the TB supposed to be lined up the way it is to the upper intake?
Had a bunch of oil under the TB hose, picture of bottom of that hose attached with throttle blade in the background
Yeah the T/B looks like its aligned well.  Z
It might be a good time to clean the CAC(Intercooler).
jbeez
I tried while i had that pipe off, but apparently my pump is busted so ill need to do that another time :(
