HN18 CHECK TURBOCHARGER WASTEGATE ACTUATOR OPERATION
NOTICE: Do not exceed 103.4 kPa (15psi) of pressure applied to the turbocharger actuators, excessive pressure will damage actuators.
Note: If the pressure bleeds off quickly while carrying out this test, find and repair the leak and retest the vehicle to verify that the initial concern is still present before continuing with this step.
Disconnect the turbocharger high pressure supply hose from the turbocharger (TC) wastegate regulating valve solenoid.
Using a suitable hand pump with pressure gauge, pressurize the TC wastegate regulating valve solenoid to 48.3 kPa (7 psi).
Ignition ON, engine OFF.
Access the PCM and control the TURBO_WGATE (PER) PID.
Command the turbocharger (TC) wastegate regulating valve solenoid duty cycle from 0% to 100%.
Ignition OFF.
Did the pressure drop when the duty cycle was commanded to 100%?
Yes
GO to HN21 .
No
INSTALL a new TC Wastegate Regulating Valve solenoid. Clear the PCM DTCs. REPEAT the self-test.
HN22 CHECK TURBOCHARGER WASTEGATE ACTUATOR OPERATION
• Disconnect the turbocharger wastegate control hose from the turbocharger (TC) wastegate regulating valve solenoid.
• Record each of the turbocharger wastegate actuator linkage positions.
• Using a suitable hand pump with pressure gauge, pressurize the turbocharger wastegate actuator hoses to 48.3 kPa (7 psi).
Did each turbocharger wastegate actuator linkage move from the starting position?
Yes
GO to HN24 .
No
GO to HN23 .
