Might and probably do have a problem here...
Noticed that my car is making a tapping almost like a screw driver taping an exhaust pipe somewhere toward the bottom end... it's very tingly sound, not a knocking sound per se...
It's very faint but once you hear it, it's very obvious...
The noise is most prevalent at idle and goes away after 2300 RPMs... I can't get it to make the noise under load..
I also noticed that while in park if I rev the motor there is a shudder at 2000 RPMs until 2500 RPMs...
I pulled plugs and they all look good....checked all the connections on the exhaust side for loose bolts or rubbing...
Next is to check oil for metal... I didn't see any on the last oil change about 400 miles ago...
