Do you still have your stock downpipes? Try swapping out the SWs.
Also monitor transmission PIDs, see if it might be the torque converter. That rpm range is a bit wide, but could be a lockup issue. Note what trans temp is at the time the stutter/shudder goes away. See if the issue occurs at cruise in that rpm range also.
