Quote from: SHOdded on January 04, 2017, 04:37:14 PMThe EB engine's optimal operating temperature (courtesy of LME) is around 140F, so the closer we can get to it without a severe compromise in emissions and all-weather drivebility, the more power we can extract from it.
Wow, 140?? Maybe optimal for power, but I don't think you could reasonably operate there without major cooling system changes.
Luckily, I read through some of this thread before leaving work, so it gave me an opportunity to mess around on my way home.
Air temp in SE Wisconsin was NINE degrees F. I have a 170-degree thermostat.
- Cruise control set at 70MPH on relatively flat ground (low-moderate load): ECT 185*F/CHT 201*F
- Coasting from 70MPH (no load) down off-ramp for approx 22 seconds: ECT 171*F/CHT 195*F
Based on this anecdotal evidence, under normal cruise @ 70MPH there's zero benefit for me running anything other than the OE thermostat, since the stat would be open anyways.
HOWEVER, notice under NO load how quickly the ECT temp came down (granted, it's ballz a$$ cold out). Using a lower temp thermostat leaves your cooling loop open for a longer period of time allowing the possibility of rejecting more total heat from the system during no load driving (braking or coasting). More rejection of heat from your coolant leaves more room to absorb new heat generated by higher loads.
If you run high load, WOT all day long, running a cooler thermostat will not help you. In racing/high performance applications, any edge in rejecting heat helps. For me, my daily driving includes a lot of low load, so I think a lower stat probably helps reject some heat between my furious passing maneuvers.
Disclaimer: I also run a surfactant in my coolant, so my numbers may or may not be typical. Not sure if the surfactant helps or not...
Quote from: AJP turbo on January 04, 2017, 06:41:51 PM
...but when the starting point is lower then the End temp will be lower as well.
This. Also why it takes so long to get warmed up in the winter with a 160 stat. Takes a lot longer to get to your "end temp" that provides sufficient heat when you are circulating the entire capacity of your cooling system in sub-freezing weather.
