Quote from: geswek on August 03, 2013, 11:18:53 PM
Both; door and button.
I already measured without bulbs; it's 12.61V on both sides.
Driver Side;
LED - 8.6V half lit
Halogen - Does not light up; shows 0.1V
Passenger Side;
LED - 12.61V fully lit
Halogen - Fully lit
If I swap these LED/Halogens around they work fine--they just do not work on Drive Side map light.
Since you say you've used opening the door to test i'm ruling out the switch on the light. The doors wire should bypass that. 0.1v across a bulb in circuit is normal. Voltage is the deference in potential from two points. Since the filament completes the circuit the only different across it is the voltage drop from its filaments resistance. If you used a remote ground you should see 12.6v on the positive side and 12.5v on the negative side showing you the 0.1v you measured. If the bulb were burnt you would still show 12.6v because the circuit would still be open. If you have 12.6v on the open socket, 0.1v across the bulb, and no light then something is limiting the current so it's not high enough for the filament to glow.
LEDs are current devices. Once a minimum voltage is reached they work off of current. White LEDs voltage drop is about 3.6v so with that and it's resistor I could see a 4v drop down to the 8.6v you measured. It looks like the led is getting its minimum voltage to turn on but again not enough current (same problem) for it to be bright.
I hope you didn't fry something when you blew that fuse. I can't think of anything "normal" that would limit current to this degree but still have proper voltage. Then again it's 5am and I'm high on sinus meds and have been up all night. Before that bulb you have the battery saver probably feeding switched +12 or zero(after x minutes of car off) to a lighting control unit that does the theater dimming when the lights go off. These could all be in the BCM and you would have to replace the whole thing requiring your dealer to reprogram it (been down that road with turn signals).
I have another test for you to try. We're replacing your multimeter with the led. Since we know both polarities are good on the passenger side we'll use those to test the drivers side. Use some wires with alligator clips on the led and hook to the positive on one side and the negative on the other then swap. Since the drivers side seems to have a problem on one wire this should be bright on one way and dim on the other.
I'd need to know how this is switched to tell you more after you see if its the + or ground wire giving you fault. I'd be very interested in seeing the wiring behind the pod but I couldn't figure out how to get it off the headliner. With the battery saver and the theater dimming there are many different ways this could be wired. Even something as stupid as the buttons controlling the lighting module.
Get me some pics of at least the back of the replacement part before you put it in. If the wires are fine, your socket contacts aren't messed up,and there's no circuitry up there I'd bet the problem is else ware.
