LEDs
Started by geswek, July 20, 2013, 03:33:22 PM
geswek
OH, I sweared -- crap; Daddy 4DR is gonna beat me now.
I fixed the photo's; apparently I linked wrong URL.
OOPS.
Great!  I think I'm gonna want to do my plate if I every get it. That really makes it pop!
geswek
Very; I hate yellow bulbs that are supposed to be white!
I got 2 more LED's coming in for back maps and I'm done.
I want to do from turn signal and marker bulb but I'm being told it's a PITA to do.
So the LED bulbs that you swapped...did they go into a 10-12 SHO or a different car?  I won't mind getting LED's for the reverse, just wondering if the first one's you got fit in my car.
geswek
Quote from: mjhpadi on July 27, 2013, 12:55:07 PM
He has a 2012 Focus.
Where is the reverse lights on your car? Trunk lid or body?
Sent from my SCH-I545 using Tapatalk 4 Beta
New lights look great, geswek!
Quote from: geswek on July 27, 2013, 01:02:09 PM
In the body.
geswek
You should be fine then.
The 13 has their reverse lights on trunk lid which means the bulb goes in at like a 60 degree angle to the housing.
If yours goes in with bulb facing straight back towards back of car you good.
geswek
I tested last night how the LEDs worked.
Reverse LEDs that I swapped with my mate are useless; they do give me a white light and they do fill the entire reflector better than the other CREE's I had, but they don't actually "project" any light--so backing up they are useless.
I found these two on ebay; not sure which one I will go with.
Rated @ 490 lumens; http://goo.gl/3cIj0j
Rated @ 500 lumens; http://goo.gl/uT6HSV
The first one may work better for my reflectors since it has so many LED's all over whereas the second one seems to have like (2) HP LEDs on each plane.
Interior LEDS
The ones I got work GREAT! Even with two back map lights still stock, the LED's overpowered the interior and make it bright white. I love it; no more "yellow" look in my car.
Even license plate looked amazing.
geswek
OK, I just ordered these LED's for my vanity lights after pulling out the factory one. They look like fuses actually.
https://www.superbrightleds.com/moreinfo/led-vehicle-replacement-bulbs/fuse-led-bulb-1-smd-led-festoon/243/1162/
So I have (2) more map light LED's coming and (4) vanity light LED's; that will complete my interior.
I also ordered this for my reverse lamp;
http://goo.gl/9NBr1w
What kind of reflector is on the '13 reverse light assembly?  Maybe a high powered festoon (all lighting elements on 1 side) would work instead?  How much space inside?
geswek
It has to be a 360 degree LED.
The first one I had was just a projector LED, didn't work as it basically pointed at side of walls.
The next LED I got from my friend was fine, just not bright enough.
The third I just ordered has a ton more LED on it so it should work.
Reflector is normal like any other. The issue is that the bulb goes in from side of light and from back like a normal tail lights.
geswek
I broke 2 more LED's; so I ordered a bunch! Those damn T10's are HARD to put into brand new sockets LOL.
Here is the vanity mirror--they look AWESOME!
Before
After
Joleat
It's disappointing that these cars cost as much as they do, but still seem to lack in some of the detail areas. I know we're only talking about lights here, but that's kind of the point. Look at what a dramatic difference is made with the LEDs.
Looks great!
Project: MKSinister-2011 Lincoln MKS EcoBoost-Tuxedo Black Metallic Exterior-Black Ultimate Leather Interior-EcoBoost Appearance Package-Unleashed SCT X4-3Bar MAP-SP534 Spark Plugs-Power Stop Drilled and Slotted Rotors and Evolution Ceramic Brake Pads-General G-Max AS-03 Tires-Debadged-Color Matched Grille-Anthracite Gray Wheels-Gloss Black Vinyl Over Chrome-35% Window Tint
geswek
Quote from: Joleat on July 31, 2013, 10:52:33 PM
Looks great!
Thanks Joleat!
I agree -- they're getting there. We have LED brakes now! LOL.
