Wass.... Good advice from Z and Manu. Both the codes are related to a stuck or biased O2sensor for bank 2 ( the front 3 cylinders) of the engine.
A bad O2 sensor, a leaking injector, or a purge valve/canister are high possibilities.
If you're wrenching yourself, I'd start at the O2 sensors... Maybe switch them and see if the code switches to bank 1.... If not I'd check the purge valve canister for liquid next. The parts to replace all three of these should be $100 or so if you chose to do that... Depending on your odometer. I'd look at the injector last personally.
If you have a warranty or don't wrench I'd recommend a dealer trip.
Just my $0.02....
I would note that this is an important kind of troubleshooting/maintenance topic that will be hard to find for others in the the future... Maybe it should be be moved to it's own thread?
Good luck Wass....
