LMS Tune, Transmission Slips & Traction Control
Started by 14SHOCAR, April 07, 2015, 09:21:22 AM
14SHOCAR
#45
Quote from: ajpturbo on April 08, 2015, 11:47:37 AM
Alcantara wheel would be the easiest...look at ur window sticker under options look for sho performance package...ask fomoco about the traction control for a 15 or read the manual
It sounds like I have a non-pp :(..
The problem as I didn't get a window sticker because I bought this used.
That explains a lot here... I wonder if I can get the upgraded cooling components...
Specifically the oil cooler and radiator...
14 Taurus SHO (Sold)
If you have the Michelins as stated earlier and a spare tire in the trunk then you have a non-PP,and who could miss that loud annoying collission alert on top of the drivers dash.
Quote from: 14SHOCAR on April 08, 2015, 11:50:10 AMIt sounds like I have a non-pp :(..
Yes, all of the auxiliary cooling components can easily be retro-fitted.
The only exception being the rear diff / PTU cooler, which is more involved.
There are links online where you can punch in your V.I.N. & be able to obtain both your window sticker &/or options list.
Currently not at a desktop to find & post them for you, but perhaps SHOdded can/will. He's very helpful/knowledgeable like that.
14SHOCAR
Quote from: IHeartGroceries on April 08, 2015, 11:53:34 AM
Where's that window sticker generator at?
I found a site to print off my sticker based on the VIN. It looks like I don't have the PP for sure.
14SHOCAR.... For vehicle info you can get a pdf of the window sticker free at http://researchmaniacs.com/VIN-Number-Lookup/WindowSticker/Ford.html
Just enter your VIN...easy... free
14SHOCAR
So what is the consensus on changing out the fluids in the drivetrain?
Where do you go to get this work done? Is it 100% dealership?
What parts do I need to take off? I'll put back the 2 bar, stock tune, but anything else (intake)??
When get the cat + exhaust, that will be a bit more of a pain to do... thoughts?
What would make u think the dealership is the only place that does fluids?...sorry you're making me evil......I say get that poop fluid out and change them all out asap
Quote from: 14SHOCAR on April 08, 2015, 01:03:38 PM
For dealership work more than Quicklane oil change always go back to stock tune.  Of course for those of us with 3BARs also change that. No dealers in PHX will do the ptu as Ford will then hold them liable if the part fails, rather than Ford corporate... I actually had this conversation with the service manager at my dealership.
Don't know about consensus... But 15K-25K for these fluids IMHO... you'll need a suction pump as the PTU has no drain plug and you'll be working through the vent. Most people are doing it multiple times at one operation to try to get more of the old fluid out...there are several threads on doing this and listing fluid types/capacities.  If the ptu fluid is thick blackened junk or has metal in it I'd recommend finding someone to remove it and clean it properly.
I don't think AM pipes will add to the difficulty.
14SHOCAR
Quote from: BiGMaC on April 08, 2015, 01:39:19 PM
So what you're saying is I can't take it to a lube place to replace this fluid or the rear diff? We have a place out here called hands on garage which has the lifts, tools etc to do whatever you need to for a vehicle. I'd consider doing the fluids if I can find the right stuff + weight.
Quote from: ajpturbo on April 08, 2015, 01:16:14 PM
Quote from: 14SHOCAR on April 08, 2015, 01:50:51 PM
Take it anywhere you trust!  Check out the lubricants though.  I have a 7 year factory maintenance policy on my car... but I take them the oil, etc...you may want to do the same wherever you go.
I do think it's good to have a relationship with the service folks at a Ford house... it has come in handy for me.
Id love to have a relationship with a dealer but I just can't bring myself to mess with them anymore when they tell me they have to drop the ptu to do the fluid lol...it tells me they are either stupid or dishonest so either way they aren't worth my time
Honestly, I'd prefer to have the unit R&R'd and opened once off for a real inspection and cleaning.... no dealer i'm near will touch it unless it fails.
