In the FSM for the Edge, under Trans specifications, I see this:
Line Pressure Chart
Gear Line
Pressures at Idle
P 372-413 kPa (54-60 psi)
R 689-724 kPa (100-105 psi)
N 372-413 kPa (54-60 psi)
D 579-600 kPa (84-87 psi)
L 579-600 kPa (84-87 psi)
Pressure at Wide Open Throttle (WOT) Stall
R 1,724-2,068 kPa (250-300 psi)
D 1,655-1,724 kPa (240-250 psi)
L 1,655-1,724 kPa (240-250 psi)
I am sure there are similar tables available in the SHO/Flex/XSPort/MKS FSM's.
