Well it turns out that the Temp sensor is the fill hole on the 13+PP cars. Unfortunately there is a heat shield in the way of that, and I just don't have enough room to get at it without a lift. I did remove the DP, I can see both the drain and the fill (Temp sensor). I just cant get to the retaining bolt for the Temp sensor heat shield. I can't even see it, I could only feel it above and behind the shield. So I am going to see if a buddy of mine has lift time available. I will keep you posted.
