I am getting excited about doing this. The last time I did an oil change, I looked the situation over and it appeared removing the plug from the bottom would be tricky - at best. I appreciate all of the "blow-by-blow" descriptions you all are providing about doing it through the wheel well.
Question: After removing the plug, are you crawling under the car to insert the tube in the PTU? I am not sure my fat @ss will fit without having the car on ramps. This job would be easier with a lift.... I guess that is beyond obvious....
