PTU fluid change frustration
Started by ecoboostsho, July 17, 2014, 11:13:32 AM
wasinger3000
You can't do it from under the car without some seriously small hands. It it's easiest to take it out from the wheel well. Then Crawl under to suck the oil out.
13' GTCS, will be missed.
Roger that. 2 6" extensions to correct myself in previous post also.
Just got in there straight shot...more extension than mentioned would be nice...had to start as far left of o2 as possible getting it all the way in and then sliding it over...very tight, but it is possible. Just can't start straight at it.
Ok...perfect setup is a 10" wobble extension off of socket to 2 6" extensions....wobble extension gives perfect amount of flexibility! !!
ecoboostsho
Got a picture?! Thanks for the feedback.
Of extension used...or where I went in at...very easy to get to with wobble extension....bought from O'Reilly's...
ecoboostsho
Thanks! Stopping on my way home. Get any fluid yet?
Just loosened bolt...cable guy just showed an hour early. ..wtf...that never happens
wasinger3000
Looks like mine did. How many miles are you at?
Pic from underneath with plug out. Looks as if it was leaking some how, but the said look of fluid is at opening and upward ?
If there is a vent tube atop the unit, could have been fluid coming out of there down the side.
