- RotM Winner
- Elite Member
- Boosted
- Logged
1.83 60ft with throttle closing 1-3 shift and got a 12.09. The main problem being the throttle closing. Under those circumstances that leads me to say it was actually a good run. 5 hours and only two runs? Sounds like me the first two times I went to the track. Clearly torque management is holding the car back....im hesitant to say its keeping your car together. Do you really think it will destroy your trans? I mean when you think heavily about it...I could understand the need to keep a close eye on it but it really sounds like the biggest setback as far as everything else you've accomplished with your build. Maybe it's just not possible to keep strategy near stock with torque management and let the car so what its been built to do..go very fast. Its like leaving the governor on. I bet you will snag an 11 full weight with baby seats and all if you take the leash off.
