May 27, 2020, 07:54:53 am
Author Topic: What have you done to your Ecoboosted vehicle today?  (Read 1873896 times)
Offline shoNoff
  • NH
  • -Given: 216
  • -Received: 652
  • Shomu the killer whale
« Reply #7155 on: October 09, 2019, 11:01:34 am »
Video coming soon.  New PB 11.39!
Hell yea buddy! F yea! Great runs nice work man. Itís great to see your hard work paying off man. Iím pissed I couldnít make it up Saturday. But as you know Iím on infant duty so itís tough to get away. Hopefully if you head back up once more I can go with you. Iíd like to video and maybe run the edge again. Good to see you finally got more then 2 passes in lmao.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
  • I'm the captain of this SHIP
« Reply #7156 on: October 09, 2019, 11:58:13 am »
Drag pack rebalanced. Picked up trans fluid and oil filter. Had a turbo feed line gasket kick the bucket on me and make a smoke show on my downpipe so got those to replace also. Got some paintless dent repair done yesterday also. A lot of little details happening on the sho
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
« Reply #7157 on: October 09, 2019, 06:23:15 pm »
Replaced the return line gasket. The feed line while very gunky wasn't wet while the bottom one was very freshly coated in oil. Got her swapped out without removing the downpipe which was a pain but better than removing it
Offline 802SHO
  • Essex Junction Vermont
  • -Given: 2070
  • -Received: 996
  • Boosted
« Reply #7158 on: October 09, 2019, 08:41:18 pm »
Thanks buddy and I am coming back again.  I'll give you a heads up.
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline 802SHO
  • -Given: 2070
  • -Received: 996
  • Boosted
« Reply #7159 on: October 09, 2019, 09:03:07 pm »
Blackstone Laboratories sent me the results today on my oil analysis of my Royal Purple 5w20 with K&N filter.  Just 1100 miles but those miles were over the course of nearly 6 months. Starting with turbo upgrades, a lot of datalogs, track time, datalogs with nitrous and track time with nitrous on stock internals.
« Last Edit: October 10, 2019, 04:54:44 am by 802SHO »
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
« Reply #7160 on: October 09, 2019, 09:59:00 pm »
Isn't the CSS supposed to come with a check valve?
It's routed like this, but by the way it was designed wouldn't the CSS let PCV gasses back into the cold side where it'll later turn into a liquid once cooled?
AJPTurbo E30 3bar rev4, SP-534 .28, MSD coils, reische 170 tstat, ARH Catless DP, resonator delete, magnaflow mufflers, airraid CAI, H&R sport springs, UPR Catchcan /w CCS, SSM "Street" RMM
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #7161 on: October 10, 2019, 01:57:00 am »
How/where the CSS is installed is critical to whether or not oil gets pulled into the airbox.  This explanation may help
https://www.ecoboostperformanceforum.com/index.php/topic,2536.msg103904.html#msg103904
Does your kit look like this
https://www.ecoboostperformanceforum.com/index.php/topic,9192.0.html
FordTechMakuloco's video on the Rx catch can setup
One of the first of many threads created by Tuner Boost, the originator of the Rx catch can
https://www.ecoboostperformanceforum.com/index.php/topic,2142.msg30117.html#msg30117
« Last Edit: October 10, 2019, 02:02:53 am by SHOdded »
Offline SM105K
  • Forum Supporters
  • Arizona
  • -Given: 832
  • -Received: 1028
  • HATER MAKER
« Reply #7162 on: October 10, 2019, 08:34:50 am »
Maybe you can just add another checkvalve at the airbox junction to prevent airflow into the airbox?  IDK.
I really don't like that diagram.  I would double check with the actual SHO diagram provided from UPR.
https://lib.store.yahoo.net/lib/yhst-37354654005614/5030-114.pdf
That is how it should be properly run. That is exactly how mine is run and it works amazing.
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Elimintor | MSD Coils | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Brakes | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline bamsho
  • south williamsport, pa
  • -Given: 171
  • -Received: 474
« Reply #7163 on: October 10, 2019, 06:04:32 pm »
Talked with my tuner today, was asked to order a smaller spray nozzle.  Ordered a M10 ftom Alky controls, currently using a M15 nozzle.  Car is running a little on the fat side.
I was surprised cause my last log I sent was with my CAI and very good cold air with temps in the mid 40s.
Offline Gofspar
  • Jr. Member
  • Phoenix
  • -Given: 5
  • -Received: 22
« Reply #7164 on: October 10, 2019, 09:21:35 pm »
Mine is exactly like this, talked to the UPR guys and he said some dudes use a k&n mini pod as a vent istead of the intake.
Might give it a try.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
« Reply #7165 on: October 10, 2019, 10:10:25 pm »
Here is my own thread on the CSS! Also another thread you might find beneficial. Z
https://www.ecoboostperformanceforum.com/index.php/topic,4419.0.html
https://www.ecoboostperformanceforum.com/index.php/topic,8802.msg132304.html#msg132304
Offline BlueSHO
  • Crete, ILliNoIS
  • -Given: 123
  • -Received: 107
« Reply #7166 on: October 11, 2019, 01:08:52 am »
The SYNC 3 APIM Module was replaced on my 16 SHO. Kept locking up and the navigation showed no the GPS symbol. Covered under my ESP..
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
« Reply #7167 on: October 11, 2019, 02:18:01 am »
Hooray for Warranty!
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • New York SHO
  • -Given: 1932
  • -Received: 4056
« Reply #7168 on: October 11, 2019, 11:43:26 am »
K&N vent Filter & Quick vent hose connector fitting and cap off the intake pipe port! Best of luck.
BTW- Here's my very own MOD I developed many years ago. Z  :)
K&N Filter- 62-1340
https://www.amazon.com/62-1340-Vent-Air-Filter-Breather/dp/B00029WXSQ/ref=sr_1_1?keywords=62-1340&qid=1570823180&s=automotive&sr=1-1
https://www.ecoboostperformanceforum.com/index.php/topic,6960.0.html
« Last Edit: October 11, 2019, 03:49:52 pm by ZSHO »
Offline Jordan
  • Columbia, Mo
  • -Given: 224
  • -Received: 642
« Reply #7169 on: October 12, 2019, 09:34:03 pm »
Finally put together my crappy footage 11.16 run. Anyways here it is.
Upset that nobody can ever film worth a damn and get it in not 360p. At least the boards are mostly readable...
* Featured Topics
* Recent Topics
Re: 802SHO 2010 Build
by 802SHO | Today at 06:17:39 am
Honestly that's not alot of $ for better flow vs our manifolds IM...
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
Re: Transfer case torque limit
by 10sleeper | Today at 12:43:07 am
My tuner just noticed that I was hitting my transfer case torque limit...
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: Thinking of trading the 16S H O
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
Add a picture of your ecoboost or your favorite ecoboosted picture! It...
Re: MrHighCALiber's SHO Forged Engine Build
by 802SHO | May 26, 2020, 05:15:44 am
That's crazy!  Looks like she won't be down for long in...
Re: EBPF Under New Ownership!
by 76fomoco | May 25, 2020, 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | May 25, 2020, 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | May 25, 2020, 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Re: Brake Cooling Kit
by bpd1151 | May 24, 2020, 07:55:43 pm
None that I've found. Although I do employ the Titanium heat shie...
Back to top
