Started by SwampRat, January 25, 2014, 04:33:17 PM
Quote from: FoMoCoSHO on September 14, 2014, 10:05:48 PMQuote from: Airbornemaikai on September 14, 2014, 09:54:31 PMWish I knew anywhere around me that had something higher than 91Is your 91 straight gas or 10% ethanol?
Quote from: FoMoCoSHO on September 14, 2014, 10:24:02 PM3 gallons of E-85 would get you to...19.00 gallons93.2 octane13.4% ethanol (or E13)Under 15% which ford has OK'd for 2013+http://www.intercepteft.com/calc.html
Quote from: Airbornemaikai on September 15, 2014, 02:29:32 AMThe most I've ever squeezed in my tank after running it as empty as I can (without going to 0 miles to empty) is 18gallons. It's actually a 18.6 gallon tank. If I go off that calculator to accomplish 93 octane on a 18Gallon tank by mixing e85 I would put 15.43 of 91 non ethanol and 2.57 of e85 for a total ethanol of 12.1% or E12. Sound right to you? If this is correct I will try it sometime in the morning
Quote from: wasinger3000 on September 15, 2014, 04:07:56 PMJust don't buy anything from Devils own injection.
Quote from: scap99 on September 15, 2014, 04:52:29 PMQuote from: wasinger3000 on September 15, 2014, 04:07:56 PMJust don't buy anything from Devils own injection.How come?And who do you recommend?
Quote from: wasinger3000 on September 15, 2014, 05:39:03 PMQuote from: scap99 on September 15, 2014, 04:52:29 PMQuote from: wasinger3000 on September 15, 2014, 04:07:56 PMJust don't buy anything from Devils own injection.How come?And who do you recommend?Call them right now and see if anyone is working other than the secretary. I bet you there isn't cause I've called every hour today to try and talk to some one. I've been waiting for an RMA for my controller that doesn't work.... that I waited 12 days for the first time. They might get more controllers in on Wednesday but they have no way of telling when or if that might happen. Yeah that's real reassuring.They just don't care. I talked to the owner to try and trouble shoot the problem. All I get is "yeah that might be it..." So far i have found zero technical competence from this company. Let alone customer service. Pretty bad bussiness if you aren't even there DURING BUSINESS HOURS to answer questions. If they do not get this resolved by Friday I'm taking my money elsewhere. Like Snow Performance. A company that actually has bussiness hours...
Quote from: FoMoCoSHO on September 15, 2014, 05:51:10 PMQuote from: wasinger3000 on September 15, 2014, 05:39:03 PMQuote from: scap99 on September 15, 2014, 04:52:29 PMQuote from: wasinger3000 on September 15, 2014, 04:07:56 PMJust don't buy anything from Devils own injection.How come?And who do you recommend?Call them right now and see if anyone is working other than the secretary. I bet you there isn't cause I've called every hour today to try and talk to some one. I've been waiting for an RMA for my controller that doesn't work.... that I waited 12 days for the first time. They might get more controllers in on Wednesday but they have no way of telling when or if that might happen. Yeah that's real reassuring.They just don't care. I talked to the owner to try and trouble shoot the problem. All I get is "yeah that might be it..." So far i have found zero technical competence from this company. Let alone customer service. Pretty bad bussiness if you aren't even there DURING BUSINESS HOURS to answer questions. If they do not get this resolved by Friday I'm taking my money elsewhere. Like Snow Performance. A company that actually has bussiness hours...This above is the best reason to MAKE YOU ORDER FROM ONE OF THE FORUM VENDORS!Sometimes spending a little more upfront will save money on the back end.Not to mention awesome service is worth a premium IMHO.
Quote from: FoMoCoSHO on September 15, 2014, 06:08:51 PMSorry....I mean I had to bust your balls a little.Hope you get everything worked out.
