Hey 4DR, I've read that the EB uses Bosch fuel injection parts.
http://www.bosch-automotivetechnology.com/media/en/db_application/downloads/pdf/antrieb/de_5/Bosch_di_folder.pdfIs any of this in our cars that you know of?
Because the specs about MAX pressures, types of fuel, etc is quite interesting.
This stuff will support 2900PSI and "worldwide qualities" fuel.
Apparently the Motronic ECU has torque based programming also
"Torque is used as the key criterion for implementing all
requirements. According to this criterion, the air-fuel
ratio is adjusted in such a way that the demanded
torque is provided as economically and cleanly as
possible. It also allows active driving safety systems
such as traction control and ESP® to intervene in the
engine torque.
Motronic can be used to control internal-combustion
engines
running on gasoline (port fuel or direct injec
tion), diesel, natural gas (CNG, liquid gas) or ethanol
as well as hybrid drives. Standardized communication
interfaces and data formats support networking with
all vehicle systems which influence the drivetrain. "
