Back when this was happening to me in 2011, Torrie told me the same thing.
Darreli who has a 2010 PP SHO has also experienced it, though he may not have had his T/C all the way off at the time. We attributed it to our Conti DW tires being hard when it was around 40 deg. Obviously, the more power you make, the more FWD spinning you will experience. That's why I feel the best option ( not perfect though) is slicks on the front and reg tires on back. If you can get both to spin some, the T/C system won't shut you down. It is the relationship between front wheel RPM's and rear wheel RPM's that causes system to Abort....
Also, if you could somehow get the RWD to accept more than 150 lbs torque, that would also slow this from happening. Maybe Ford will beef it up in future EB (FWD based) platforms.
