Started by sunwolf, May 19, 2015, 12:11:29 PM
Quote from: sunwolf on May 19, 2015, 02:58:51 PMOk thanks. How long did it take you to install yours?
Quote from: ZSHO on May 19, 2015, 03:08:21 PMQuote from: sunwolf on May 19, 2015, 02:58:51 PMOk thanks. How long did it take you to install yours?Due to it being my second set,it was easier and took roughly about 90 min for the DP install,BTW your going to love hearing those turbos spoooool,enjoy. Z
Quote from: sunwolf on May 19, 2015, 03:16:12 PMQuote from: ZSHO on May 19, 2015, 03:08:21 PMQuote from: sunwolf on May 19, 2015, 02:58:51 PMOk thanks. How long did it take you to install yours?Due to it being my second set,it was easier and took roughly about 90 min for the DP install,BTW your going to love hearing those turbos spoooool,enjoy. ZWould love to hear them spool today but the shop called and won't have it ready until tomorrow.
Quote from: sunwolf on May 19, 2015, 08:41:48 PMSo after 40 miles the exhaust has started to make this sound like it's vibrating and the two pipes are hitting each other under 8 psi boost Under 40 mph.
Quote from: ZSHO on May 19, 2015, 10:09:02 PMQuote from: sunwolf on May 19, 2015, 08:41:48 PMSo after 40 miles the exhaust has started to make this sound like it's vibrating and the two pipes are hitting each other under 8 psi boost Under 40 mph.I would make sure they used the bolts that came with the DP,and as mentioned earlier and many other posts to re-torque the bolts due to heat expansure,and use some antiseize . Z
