installing exhaust today
Started by sunwolf, May 19, 2015, 12:11:29 PM
sunwolf
I am having my friends shop install LME catted downpipes and a magnaflow xpipe today. He just called me and said the opening in the flanges is about half an inch off at the flex pipe end. Is this normal because of the larger diameter pipes? Do they bolt up just fine with no leaks?
2014 Taurus SHO Black Performance Pack LMS tune 3bar tstat downpipes
2008 BMW M6 Convertible SMG
2008 F-150 XLT 4x4 5.4L
2011 F-150 Ecoboost Crew Cab 4x4
2012 Lincoln Navigator L 4x4
I think you should be good,take a look at the pics below which should help,make sure to re-torque those bolts after a couple of hunded of miles. Z
sunwolf
Ok thanks. How long did it take you to install yours?
Quote from: sunwolf on May 19, 2015, 02:58:51 PM
Due to it being my second set,it was easier and took roughly about 90 min for the DP install,BTW your going to love hearing those turbos spoooool,enjoy. Z
sunwolf
Quote from: ZSHO on May 19, 2015, 03:08:21 PM
Would love to hear them spool today but the shop called and won't have it ready until tomorrow.
Quote from: sunwolf on May 19, 2015, 03:16:12 PM
How long has the car been there?did you get a price quote?
sunwolf
It has been there all day. I can't complain too much because he usually does not charge me for labor even though I told him to charge me something for this job since welding is involved.
sunwolf
And now the downpipes are done. X pipe needs to be ordered so I might put that on later.
sunwolf
#8
So after 40 miles the exhaust has started to make this sound like it's vibrating and the two pipes are hitting each other under 8 psi boost Under 40 mph.
Quote from: sunwolf on May 19, 2015, 08:41:48 PM
I would make sure they used the bolts that came with the DP,and as mentioned earlier and many other posts to re-torque the bolts due to heat expansure,and use some antiseize . Z
sunwolf
Quote from: ZSHO on May 19, 2015, 10:09:02 PM
My downpipes didn't come with bolts...
MICHAELxMLB
Also there's a heat shield on the downpipe closest to the passenger side that I had to bend back a little because it was vibrating against the downpipe. I'd check that too
68_GT
tell us about the sounds etc once you get it straightened out.
problems has to be the heatshield or something simple.
sunwolf
I think it is something simple. It sounds like a medium pitch humming that only occurs at specific boost and speed levels. The pitch isn't right for me to call it drone but that's kinda the idea I have of it.
Is it a "whine" type sound from driver side?
Rich
