13-14 Sho Chrome stripes
Started by CroR1, October 23, 2014, 01:16:31 PM
CroR1
The lower grill has a chrome strip running along, and it wiggles. Is it removable from the lower grill or is it a single piece? I want to remove it, but I do not want to break it. Any thought, anyone done it?
Chrome along the doors, is it removable and replaceable with black stripes? Anyone done it, and how?
I take it the front upper grill is a one piece and has to be replaced for a black one. Any input?
Side sho badges, do they just pop out? I'm assuming those are held with just clips?
Any thoughts and inputs would be appreciated.
Thank you in advance.
Not sure about the bumper moulding. But the sho side badges are held in with plastic clips that are moulded into the badge itself. They're pretty easy to get out. Just be careful you don't  break the clip
CroR1
Thank you, side/fender badges was an easy one, lol. Now the difficult ones :)
Whole front facia has to removed to remove grills. The chrome trim on doors is virtually impossible to remove without damaging and I've got nearly 30yrs experience in the factory.
CroR1
Quote from: crash712us on October 23, 2014, 03:11:12 PM
damaging the trim on the door, or the door itself? if there is a replacement, I wont mind if the chrome trim gets damaged. Has anyone tries the plastidip, how many coats, and how well is it holding up?
The trim. Many have plastidipped. But I have not
You could do a vinyl wrap instead of the plasti-dip. I did plasti-dip on the rear chrome, holding up ok so far (4 months). I did 3 coats, making sure the first one wasn't to thin, if it is I hear it's a pain to remove.
Rich
CroR1
I did the rear/trunk piece too about 4 months ago, it looks so much better. however, I haven't driven the car much since, and it's still there like the day when I put it on. I guess I might try doing plastidip on the door, it just seems like a pain to mask tape around it. maybe in spring I'll do the door after I  see if the plastidip grill holds up over winter. plan is to find an PI grill in tact.
Did you see the pic I posted in the exterior mod section. 4.2 SHO custom grille, it is chrome, but could become black quite easy.
Rich
slurppie
Did this about 2 weeks ago. Longest part was taping everything off. Since there isn't a clean break on the trim, you have to lay down wet coats then remove tape before it dries.
2013 w/PP
Synthetic blinker fluid
Ceramic muffler bearings
Looks solid slurppie. How's it holding up over the short time span?
Rich
slurppie
So far so good. A good prep is key for spraying and after a week it seems to have fully cured.
2013 w/PP
CroR1
Yes, i just saw the pic. indeed, very nice. Painting it black while it's off the car is a good idea lol. I am not a big fan of chrome, eventually I would like to get one of those grills that don't have the ford badge in the middlle, or the PI grill.
the door plastidip looks good, i am not a fan of it as it is not a long term solution. I would like something permanent, but if all else fails, I might give it a shot.
Having my windows tinted, I like the border the chrome provides between paint and black windows. Sort of makes them stick out better to me. If I do ever decide to black out that door trim, I'm gonna go with vinyl, high traffic area makes me think an edge could get caught up quite easily and peel.
Rich
