EBC Front
Started by jtoddk98, June 01, 2014, 08:42:32 PM
Quote from: jtoddk98 on June 09, 2014, 08:12:27 PM
Ordered them last week. Should be here tomorrow. Any break in procedure for these? Or just drive like normal
How to bed in your new brakes for street/urban driving
BEDDING IN NEW EBC PADS AND DISCS
Use brakes with minimal pressure for first 100 miles from urban speeds of 30-50 mph only. Brakes will feel very sharp and responsive but this is ONLY the brake in coating working which gives an abnormally high friction level feeling.Drive a further 250 miles using slightly increased brake pressure and load UNLESS in an emergency in which case apply brake as hard as required.Clean wheels off as there will be residue from the brake-in coating after bed in.Look for a full width contact across the pad depth( rotor braking band) from the outer edge of the disc to the inner and if not achieved allow a further 100-200 miles steady driving. You will see a blue-ish band evidencing contact across the rotor face. Until this band goes from the outer to the inner edges of the brake disc/rotor the pads have NOT yet fully seated. When installing new rotors, reduced width banding is quite possible due to various tolerances and slight misalignments in the vehicle chassis and is NOT a warranty defect or a reason to remove and inspect brakes. Many European cars have SINGLE PISTON CALIPERS and these tend to "Flair" open and cause the contact band described above only to be seen at the outer edge of the disc/rotor and work its way inwards taking up to 1000 miles to do so.After full width contact band is attained make a further 10 stops from 60 mph to 10 mph in succession with a deliberate attempt to get the brakes hot. Some smells may occur even slight smoke during this final heat up stage of the pads in early life. Then coast the vehicle for a mile to allow discs to cool. Do not pull up and park vehicle with brake excessively hot. You must try to get the discs down to below 60-80 degrees C temperature before parking the vehicle.When parked let brakes cool to a final cool-to-touch point. Before touching discs splash a few tiny drops of water onto the disc to asses its temperature to avoid burning fingers. If the water spots cause a "hiss" you have parked up too soon and should go out and drive slowly allowing the brakes to cool further.
NEW DISCS TAKE LONGER TO BED IN
Fully bedding new pads to decent condition worn discs/rotors may take only 200-300 miles but when new discs are fitted at the same time bed in times to achieve outer to inner edge contact ( full width blue-grey contact band as mentioned under point 4 above ) can be as long as 800-1000 miles due to extra components needed to be aligned to the vehicle. To Short cut this you can ( and EBC recommend should) have EVEN NEW DISCS Pro Cut Lathe aligned to your vehicle. This process removes only microns of new disc material and shortens bed in time by 75% of the time it COULD take giving you better brakes faster and avoiding hot spotting and pad glazing.
BADLY WORN DISCS/ROTORS CAN TAKE AN AGE TO BED IN
Discs/Rotors with more than 0.5 mm ( 0.020 inches) of lip at the outer edge or hollow in the centre of the braking area can take up to 2000 miles to bed in and will for sure cause Noise, brake fade,vibration and pad burning. Bad rotors can RUIN your pads. 95% of brake fade and noise complaints come from poor disc/rotor condition where the pads touch only at the outer and inner edges and have no chance to deliver an effective brake.
Again new Discs/rotors is the solution or a Pro Cut on car Brake lathe re alignment.
2010 RCM non PP
K&N panel filter
sp534 @ 30
unleashed 93 performance+boost
more to come.....
jtoddk98
That sounds like a lot of fun. Haha.
jtoddk98
they came in! look great. probably getting them on this weekend.
Your going to love them.
Huge improvement over stock.
Kolk1
I have the kit posted in the first post, front and rear, and I dont know, maybe its me since Ive had tons of brake issues with this car, but mine hum at medium braking. They stop great, just hum a little. None of my other brakes have ever hummed before this set.
I also bought steel braided lines I havent put on yet. Im almost debating on buying a 4th set of brakes for this car, and do it then.... :(
I get the hum also.
Ebc mentions some cars do it more than others.
Kolk1
Quote from: glock-coma on June 20, 2014, 07:58:22 AM
I get the hum also.
Yea, I almost went with the gold/yellowish rotors, but supposedly they have even more road noise. One day Ill find the perfect setup for me. Sadly, its probably the $2500 front kit they sell. lol
Wonder if it's a sympathetic resonance that can be dampened by adding shims to the pads?
MDesign Performance
Quote from: SHOdded on June 21, 2014, 12:25:38 AM
It's just air passing over the rotors in the slots, the reason the USR are meant tone the quietest slotted rotors are due to the slots being broken up in half, 2 small slots = less wind noise than 1 large slot.
2011 MKS EcoBoost: MDesign Carbon Cold Air Intake; SP-534 Plugs; Power Stop C/S Rotors
sales@mdesignperformance.com
www.mdesignperformance.com
www.facebook.com/MDesignPerformance
Brake aerodynamics, LOL!  I'll have to pay closer attention to mine for sound now.  I have only heard the periodic chuk chuk chuk where the slots & holes are in the rotors, but no humming of any kind.
jtoddk98
Installed today. Love them. Pedal feels much better. Great upgrade. Don't hear any humming. All good
Quote from: jtoddk98 on June 25, 2014, 03:31:47 PM
I only notice some humming on medium/heavy breaking.
Its not noticeable from outside the veichle.
2010 RCM non PP
K&N panel filter
sp534 @ 30
more to come.....
