Quote from: ddlopes on September 01, 2017, 09:27:40 AM
I ordered some Boostane to add to my fuel to see if the 93 pump gas or meth is junk. Hopefully it'll come in today.
Quote from: TopherSho on August 31, 2017, 10:51:12 PM
Interesting things to note.. after cutting the data before the high speed and after the high speed (attached to post) I can see up to +7kr .. BUT it only occurs after shifting.
during the non-shift WoT your only hitting 18spark on average but it is stable.. it is low for meth in my humble opinion but it is behaving as it should.
what is your elevation ?
others will need to chime in but this looks like a tuning issue or a fuel quality / meth quality issue or issue with meth delivery issue with the nozzle..
So there is something funky there.. for sure... you are not running a ton of boost and spark is conservative but you are pulling 8 degrees of spark...
IE. You are commanding 196.98kpa of boost (13.87psi) and hitting 19 degrees of spark on the multigear run and 23 on the third gear pull.. Brad has mine at 205kpa (15psi) and 28 degrees of advance and I have no knock retard.
So its normal to run a little richer than the command AFR when the meth starts spraying as it takes a split second for the ECU to pull the data from the widebands and make fueling adjustments. You are pulling about 15% fuel through the widebands but combined with your LTFT you are really only pulling around 11%.. which is NOT bad for spraying meth... I usually spray a bit more more than that..
What stands out is obviously the 8+ degrees of KR but how the meth is being delivered... its very inconsistent.. at least on bank 1.. the widebands should have a pretty linear appearance through the run (unless you are using the throttle to control load which you are NOT).. example would be that on the 3rd gear pull your wideband has a pretty gnarly upturn and i don't understand why.
It would be beneficial to see what bank 2 looks like honestly. Unless you are direct port meth like ZSHO, then bank 1 tends to get more meth than bank 2.. bank 2 could not be getting much spray so its knocking? We would need to see a log with bank 2's stats... Wideband (STFT and LTFT) along with lambase and lambda.
I don't see a fueling issue here from the standpoint of HPFP, LPFP, and how your car is reacting to the spray its getting. COuld it be a bad tank of gas? I have had this happen... scary as F when spraying to get a bad tank of gas...Maybe bad meth? Are you running 100% meth?
At this point, I am pretty sure the pump appears to be working.. but we need to see bank 2.
