WE Drilled and Tapped the PTU Yesterday, WHAT FUN
AND for anyone that DOES NOT want to Do that And Drill it
AN EASY WAY to DRAIN and FILL utilizing the Bulb type Pump,
ALSO if you have aftermarket Down Pipes, that make it difficult to
run the Hose down into the bottom of PTU, I offer this easy solution...
1/4 Copper X 6" approx (i used Stainless Steel ) tubing with a 120 Deg Bend @ one end
(120 Deg Approx., may have to adjust the radius and also cut the end down)
Add a small piece of the tubing (about 3") to the bent end and Behold:
An easy way to get the tubing to the Bottom of the PTU, with one hand even..
AND to fill, Remove the 3" hose and reverse your New Gear Oil right in.
