I tried working on the "new" show the other day and swap in colder plugs. removed the bolt holding the coil pack on, and the wire. tried pulling he coil out and it would not come out. I tried twisting it a little bit, but it just would not come off? I do not want to pry on it and risk breaking something.
I just got the service records for the car, religious and routine oil changes by dealer so I do not see the PO taking it anywhere else for plugs, which means they are the original factory plugs.
Anyone have any thoughts or ideas? I saw a video about having to pry/use pliers on the coil pack seals around the plug, but I cannot even get the coil off to get that far. Thinking strongly about just letting the dealer do a plug swap with std plugs to break everything free, and I will then replace with colder and be sure to use dielectric grease on the boots?
