Quote from: AJP turbo on January 06, 2017, 07:51:16 PM
Quote from: StealBlueSho on January 06, 2017, 07:42:05 PM
Quote from: AJP turbo on January 06, 2017, 07:11:25 PM
That is absurd...waste of a car
I really can not see LMS boost levels of 190 kpa being a problem for fuel pressure for regular E10 gas at ANY temp..i enjoy going wot on a turbo car when its cold..they love it
The 10 degree ambiant temp really doesnt matter...once warmed up to operating temp id say your iat2 is around 50+ anyway so thats what the engine is really seeing
IIRC the 4+X tune on the 2010-2012 calls for 187kpa under WOT... and that's the most aggressive one... although timing is pretty up there around 23 degrees advanced....
In have run that one in under freezing temps without an issue... hammering on it.. no problems...
Timing is pretty up there as you say because at 185 kpa load is lower and the spark tables follow load so lower load will yield more spark...and that spark was also your car and we know your car loved the spark
Take a look at an explorer sport under the same conditions and i bet you wont see 23 degrees....for some reason they dont tolerate the spark
Makes sense, when boost is lower the timing is higher in the logs I see... I just assumed that was traditional tuning boost vs spark... raise boost where you want it and slowly add timing into it until you start picking up knock then back it off a bit...and generally it's a give and take.. more boost or more spark... not cranking hard on both... at least as I understand it..
The only logs of guys running more than 21 degrees of spark without knock are mixing E at 20% or higher...
Although FoMoCo had some interesting logs running really high E mixes..
But I digress... the OP shouldn't be seeing hesitation issues unless something outside the range of normal is not correct.
