Oh my, ok. So while digging around looking at the rear soaking turbo I noticed a new problem. No matter what, cold, hot, sitting over night, the second I start my car my fans kick on. And on top of that, my car wont heat up. Obviously I thought the fans on were keeping it from warming up my car so I unplugged them and my cars temp still wont budge. It's stuck on cold. I monitored the ect through scanner and it read no higher than 138 degrees and when I drive it drops to like 105 degrees. Like
?? I changed the t stat twice both with oreilly brands. Is oreilly brands the problem? I pulled the ect/cht sensor and measured resistance as I dipped it in boiling water. Resistance did drop, rather fast so maybe its faulty or out of spec? And I'm also wondering if the non warming up and fans running constantly are 2 separate probs or one in the same. I checked the fuses (no relays for fans) and all is good. I'm really lost. Is the fan control module faulty? Can that be tested? Someone please help!!!!!!!! I have a new ect temp sensor coming tomorrow to see if that helps.
