July 20, 2019, 01:15:04 AM
Author Topic: 2013 XSport - DTC P0016 - Camshaft Position Correlation, Bank 1  (Read 2599 times)
Offline ebutler92
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 8
  • Ecobooster
Re: 2013 XSport - DTC P0016 - Camshaft Position Correlation, Bank 1
« Reply #15 on: March 08, 2019, 08:01:36 AM »
My 2014 Explorer sport has come up with a similar issue. The other day I noticed a stutter/engine shake during light acceleration under load. Shortly after during my drive an engine light came on and I scanned it resulting in a P00016 code. I immediately replaced the specified cam sensor that my reader recommended and cleared the light. Upon driving after replacement, the light hasnít come back but the stuttering/shaking continues. Research is showing a possible timing chain issue as well. Any other insight?
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #16 on: March 08, 2019, 08:21:07 AM »
Sounds like the beginning of timing chain/tensioner failure.  Will eventually destroy the water pump as well.  Best advice is to take it in and have it serviced as soon as possible.
Offline MiWiAu
  • Elite Member
  • : Milwaukee
  • Thank You
  • -Given: 289
  • -Received: 395
  • EcoBoobster
« Reply #17 on: March 08, 2019, 08:30:46 AM »
How much have you driven it since clearing the code?
I got the P0016 code once last winter (about a year ago) on a very cold day and cleared it, and it didnít come back again until last week.  I thought it was a fluke due to persistent sub-zero temps.
CEL came on again last week with P0016 code. I immediately cleared it, and it came back 24 hours later (~80 miles). I left the code this time and the CEL stayed on for 3 days/~120 mi before turning off again on its own. Came on again the following morning after ~20 miles.
The following day, I swapped the CPS bank 1/2 sensors, cleared the codes, and P0016 came back again the next day, so the code did not move with the sensor, and it was persistent in triggering the fault.
Thatís when I decided to take it to the dealer. If I had to do it over again, I would have shopped the repair at a couple of repair facilities, but my situation did not afford me the luxury of time to do this, and Iím paying for it (literally).
TL/DR: You may just need to drive a little more before it comes back on, but unfortunately I doubt it will go away on its own.
2013 XSport
Offline ebutler92
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 8
  • Ecobooster
« Reply #18 on: March 08, 2019, 08:34:22 AM »
Since reading this thread and a few others I have scheduled to have the timing chain/water pump replaced ASAP. Luckily when I purchased this sport I bought an extended warranty so hopefully this should only cost me my deductible.
Offline MiWiAu
  • Elite Member
  • : Milwaukee
  • Thank You
  • -Given: 289
  • -Received: 395
  • EcoBoobster
« Reply #19 on: March 08, 2019, 08:38:05 AM »
Also, just curious, how many miles do you have on your XSport?
If it is confirmed to be a timing chain, I would recommend lodging a formal complaint with Ford Customer Care.
IMHO, this failure (in my case at 74k miles) is a joke. I pleaded with the service manager and Ford Customer Care for some repair assistance, but they refused, since I am out of warranty. Both told me to save my repair invoice in case Ford launches a repair campaign in the future (possible reimbursement). I wonít hold my breath, but  going to file away that receipt.
If complaints keep rolling in, maybe Ford will eventually do the right thing.
Makes me wonder if weíll see a lot more of these as the earlier Gen 5 Explorer Sports are getting some miles on them. :(
2013 XSport
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #20 on: March 08, 2019, 08:41:00 AM »
Since you are out of pocket, Mike, be sure to get the old parts back and post pics.  If you had warranty, they generally refuse to give you the old parts back.  Let's see what was in your XSport.  Should be the dual toothed water pump and appropriate timing chain, but let's see.
Offline MiWiAu
  • Elite Member
  • : Milwaukee
  • Thank You
  • -Given: 289
  • -Received: 395
  • EcoBoobster
« Reply #21 on: March 08, 2019, 08:41:07 AM »
Good luck! Getting it done under warranty ought to also get it on Fordís radar.
Glad to hear you have the ESP, because I have a serious case of the woulda/coulda/shouldas right now! :P
Keep us posted on the diagnosis!
2013 XSport
Offline ebutler92
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 8
  • Ecobooster
« Reply #22 on: March 08, 2019, 08:41:20 AM »
Mine actually just rolled 100k last week. So significantly more mileage than yours. Iíve also ordered a catch can for mine. Been smelling a oil burning odor from the car recently as well. My first ecoboost so Iím new to all these issues.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #23 on: March 08, 2019, 08:41:51 AM »
Always get the old parts back.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #24 on: March 08, 2019, 08:42:25 AM »
Oil burning may be a valve cover and/or turbo issue most likely.
Offline ebutler92
  • Jr. Member
  • Thank You
  • -Given: 2
  • -Received: 8
  • Ecobooster
« Reply #25 on: March 08, 2019, 08:43:22 AM »
Does the engine always get pulled for this repair? If so my extended warranty covers gaskets and what not as well. Might as well have him to it all if itís out.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #26 on: March 08, 2019, 08:46:33 AM »
Depends on the shop.  The manual says no need, but I see dealer AND nondealer shops pulling the engine anyway.
Offline MiWiAu
  • Elite Member
  • : Milwaukee
  • Thank You
  • -Given: 289
  • -Received: 395
  • EcoBoobster
« Reply #27 on: March 08, 2019, 08:46:45 AM »
I donít want to jinx you, but the burning oil smell might be the PTU. That should also be covered under the ESP as well. Iíd have them look at that when you bring it in for the code, so you donít have to pay your deductible twice.
EDIT: The burning oil smell and the shudder/vibration you are experiencing during acceleration are both potential symptoms of a PTU on its way out.
« Last Edit: March 08, 2019, 08:52:07 AM by MiWiAu »
2013 XSport
Offline MiWiAu
  • Elite Member
  • : Milwaukee
  • Thank You
  • -Given: 289
  • -Received: 395
  • EcoBoobster
« Reply #28 on: March 08, 2019, 08:50:53 AM »
I called the SA and asked for the old parts.
What do you do with the old parts other than post sweet pictures to EBPF? :)
I assume for something like a PTU replacement, thereís a notable core charge.
Iíve always done my own service, so never saved anything, but this job was more than I had time for.
2013 XSport
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11283
  • -Received: 3732
« Reply #29 on: March 08, 2019, 08:55:01 AM »
you are paying out of pocket, no such thing as a core charge.  they may give you a refund if you let them keep the old parts, IDK, you would have to ask.
* Featured Topics
* Recent Topics
by MKS Tom | July 19, 2019, 11:08:07 PM
Is it possible to get into the 10s?  I mean, ANYTHING is possible...
Re: Any roofers?
by FoMoCoSHO | July 19, 2019, 07:35:39 PM
Home inspectors, jack of all trades master of none.It needs sisters......
Re: Inferred Octane
by FoMoCoSHO | July 19, 2019, 06:10:48 PM
Is OAR another way of displaying inferred octane? Or is more of an ind...
Re: Random thoughts for the day
by SHOdded | July 19, 2019, 04:06:00 PM
Big moves :)...
Re: I-G35!
by shoNoff | July 19, 2019, 01:35:44 PM
Good idea on the roof. Car looks awesome. It amazes me how up to date ...
Re: Queens addition
by Dxlnt1 | July 19, 2019, 01:01:26 PM
RIP to the goat! Pure Pontiac muscle. Another true sleeper car that on...
Re: Yet another failure
by polskifacet | July 18, 2019, 05:20:16 PM
There are 1000s of diffs because the "carrier" is the same a...
Re: rough idle no accel response and P0087 code
by Livernois Motorsports | July 18, 2019, 02:10:28 PM
That is excellent news!  Glad to hear that module did the trick.&...
Re: A sad, sad day in the history of my SHO.....
by TopherSho | July 18, 2019, 09:00:24 AM
I have a few more things to add, I have read this whole tread many tim...
Re: Random questions and shameless plug
by Black Dream | July 17, 2019, 07:48:34 PM
I haven't dug any deeper yet.  I bought new headlight bulbs ...
Re: Saw a Potential Upgraded Transmission on FB
by JagerBomb | July 17, 2019, 12:42:16 PM
Just to update, N. O. fell off facebook and had a falling out with oth...
Re: Taurus sho trans upgrade
by JagerBomb | July 17, 2019, 12:38:59 PM
Is there any company working on performance upgrades for the 6f55? Sen...
Re: "How-To" wire up a switch so you can manually turn the fans on - Kolk1
by TimmyATL | July 17, 2019, 08:55:55 AM
Yall might want look at the wiring diagram for the cooling fans. On my...
Re: ďAWD offĒ message on long drive
by SHOdded | July 16, 2019, 04:52:53 PM
If the tires prove out then yes it would seem.  Or maybe the not ...
Re: Change out headlamp bulb - MKS vs SHO???
by Simonsays | July 15, 2019, 06:12:03 PM
My mks had torx screws holding it in as I have adaptive turn lights. I...
Back to top
