May 27, 2020, 08:29:24 am
Author Topic: 2013 XSport - DTC P0016 - Camshaft Position Correlation, Bank 1  (Read 7844 times)
Offline Macgyver
  • Super Moderator
  • Elite Member
  • Reading, Pa.......
  • Thank You
  • -Given: 89
  • -Received: 286
  • Ecobooster
Re: 2013 XSport - DTC P0016 - Camshaft Position Correlation, Bank 1
« Reply #75 on: May 14, 2019, 10:34:08 pm »
timing tensioner?
I believe he was referring to the serpentine belt tensioner. Will confirm shortly when I pick up.
Iím a bit skeptical, but trying hard to give them the benefit of the doubt. Worst case, I bring it back tomorrow...
So when did you get the ESP ? I was thinking about getting one soonish.
Offline MiWiAu
  • Elite Member
  • Milwaukee
  • Thank You
  • -Given: 297
  • -Received: 400
  • EcoBoobster
« Reply #76 on: May 15, 2019, 07:14:49 am »
Just a couple months ago right after the timing chain failure before I rolled 75k miles.
I got mine through Ziegler Ford for over $1000 less than I was quoted by Ford ESP direct.
I opted for the 60k/48 mo plan, which was the most I could add with my current mileage. Thereís an inspection form that the dealer needs to complete, which ran me $125.
https://www.zeiglerfordesp.com/process/quickquote.aspx?type=primary
« Last Edit: May 15, 2019, 07:23:09 am by MiWiAu »
2013 XSport
Offline MiWiAu
  • Elite Member
  • Milwaukee
  • Thank You
  • -Given: 297
  • -Received: 400
  • EcoBoobster
« Reply #77 on: May 15, 2019, 08:19:09 am »
timing tensioner?
Confirmed - they replaced the serpentine belt and tensioner.
My skepticism is waning. After several days of this rattle (consistently appearing 45-60 sec after a cold start), there was no noise this morning...
Repair order attached for posterity.
2013 XSport
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 12953
  • -Received: 4203
« Reply #78 on: May 15, 2019, 09:37:45 am »
Would be great if this is true, fingers crossed :)  First instance of rattling caused by belt tensioner.  Usually it's like cards in bicycle spokes kind of "flitting" sound, mostly on colder days/near freezing & below.
Offline MiWiAu
  • Elite Member
  • Milwaukee
  • Thank You
  • -Given: 297
  • -Received: 400
  • EcoBoobster
« Reply #79 on: May 15, 2019, 09:57:54 am »
Yeah, I definitely would have guessed chain slap. Didnít sound like any tensioner/belt issue Iíve heard.
The little nugget in the repair order is to remove the accessory belt and see if the noise goes away. I could have done that, but I was convinced it was timing chain related.
Iíll check back if the noise returns. :)
2013 XSport
Offline MiWiAu
  • Elite Member
  • Milwaukee
  • Thank You
  • -Given: 297
  • -Received: 400
  • EcoBoobster
« Reply #80 on: September 10, 2019, 10:55:15 am »
FYI, my coworker told me this morning that he got a P0016 code on his 2014 XSport with 73k miles. He bought it new and it's all stock.
2013 XSport
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 12953
  • -Received: 4203
« Reply #81 on: September 10, 2019, 11:04:20 am »
Sorry to hear :(  Best I can say is coolant needed to be changed or maybe shoulda been running full synth all along.  Doesn't seem to be a place to point the finger tho.
Offline MiWiAu
  • Elite Member
  • Milwaukee
  • Thank You
  • -Given: 297
  • -Received: 400
  • EcoBoobster
« Reply #82 on: September 10, 2019, 11:41:55 am »
Yeah, I donít have any details on his service history, but I found it curious that heís experiencing similar symptoms at nearly the same mileage that I had.
If he has it diagnosed/repaired, Iíll update with any new info. :)
2013 XSport
* Featured Topics
* Recent Topics
Re: 802SHO 2010 Build
by 802SHO | Today at 06:17:39 am
Honestly that's not alot of $ for better flow vs our manifolds IM...
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
by 10sleeper | Today at 12:43:07 am
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
by 802SHO | May 26, 2020, 05:15:44 am
Re: EBPF Under New Ownership!
Re: EPP CAI
Re: Letís talk weight reduction?!
Re: Ford Recalls
Re: Brake Cooling Kit
Back to top
