- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: ZSHO on November 17, 2018, 06:04:01 PM
I don't know where to start but it was a pleasure meeting up with Manu (SHOdded) once again and awesome to have enthusiasts like him representing the ecoboost platform/community.
I guess with the final Track days looming while trying to get the Redhead prepared by having the the PTU Fluid flushed-Spark plugs and brand new 02 sensors installed as many of you are aware of...
I was unfortunately frustrated and only was able get TWO runs in while noticing on my 2nd run that there was much wheel hop upon launching and something must be a miss while suggesting its the PTU which the Ford dealer recently screwed up AFAIK!
FWIW I do have a PB of 1.752 60' time prior to having the PTU Flush performed and just lost for words @ the moment as my Quest for the elusive 11's has come to a screeching Halt for the time being!
Time slip below with a Trap Speed of almost 116 mph and was able to gain a kill @ least against a new 5.0 Stang once again. Z
Your trap speed says it all. It's proof you're pushing some serious power and proves you are capable of a breaking the 11 barrier. Something about that 60ft was clearly off. It's a shame you were only able to get two runs in! Some of my PB were had by second to last run out of 5 or 6 runs.
I agree the PTU issue could be the culprit. Its the first thing that comes to mind. I wasn't there but if you went through the water box as well...certainly doesn't help and it sounded like that was unavoidable.
Spark plugs and O2 sensors...no way.
Track prep perhaps? I think when track prep is off even a little it really affects our street tires. Something that even the really fast cars with drags and slicks don't get affected by much. When I ran my best time and 60ft i was literally the first one down the track in the right lane for the start of the day. Track prep was perfect for my tires.
I'm glad you were able to still leave on a positive, meeting with with Shodded...its a lot of fun to meet up with another member and friend. When it works out to meet up with Tim (ShoNoff) it's always more fun.
