oil all in my intake ?? new engine / turbos & loosing patience with my 13 PP.
Started by 68_GT, January 24, 2018, 07:52:43 PM
68_GT
thanks a million ! my mind is fried stressing over this so I missed that link. I have it all now.
So if my current wiring doesn't have the wires for the updated CKCP sensor how do I fix this ?? Or do I need an updated metal valve cover, PVC, and oil separator ??
I think the CKCP sensor (EGR) feedback pressure Sensor was implemented on the 2015MY -XSPORT IIRC! So No worries!   :)
I just wanted to confirm verify that you did not have that sensor! '
I think you also might need the front vent tube/hose!  Z
AA5Z-6758-E - Hose
$12.86
$60.42
AA5Z-6A785-F Oil Separator
$4.86
AA5Z-6A666-D  - PCV Valve
https://parts.levittownfordparts.com/oem-parts/ford-separator-aa5z6a785f/?c=Zz1lbWlzc2lvbi1zeXN0ZW0mcz1lbWlzc2lvbi1jb21wb25lbnRzJmk9S0QwOTIxNzUmcj05JmE9Zm9yZCZvPXRhdXJ1cyZ5PTIwMTMmdD1zaG8mZT0zLTVsLXY2LWdhcw%3D%3D
https://parts.levittownfordparts.com/auto-parts/2013/ford/taurus/sho-trim/3-5l-v6-gas-engine/emission-system-cat/emission-components-scat
68_GT
68_GT
68_GT
68_GT
The front and rear hose/tube can be had for fairly cheap and would order them just in case your current ones don't fit or reach! Z
Number 11 & 12 needed! On Diagram below l
Did you happen to check for any codes?  Z
68_GT
Quote from: ZSHO on January 25, 2018, 11:24:56 AM
Number 11 & 12 needed! On Diagram below l!
So basically you are thinking I need to update these parts like the TSB did ?
Colorado-SHOBro
Quote from: 68_GT on January 25, 2018, 10:17:46 AM
Pics
FWIW i looked at my 11' this morning and everything was identical to yours EXCEPT mine does not have the connector that's strapped to the oil separator in the above pic. not sure if that connector might be related to the pcv system or may be the CKCP sensor in question?
12.8@108 @ 6,000ft DA.
Quote from: Colorado-SHOBro on January 25, 2018, 01:13:50 PM
Pics
If that was the CKCP Sensor it would be by the front valve cover!
It looks like that strap was put there intentially to keep the wiring @ bay! IMO!
The PCV Valve alone looks beat-up and should be changed!  Z
Colorado-SHOBro
Quote from: ZSHO on January 25, 2018, 01:23:23 PM
Pics
Correct. I should have been more specific. Maybe that is the harness where the CKCP sensor connects to? That connector just stood out to me since i don't have it on my 11 although the pcv/oil separator system is the same as the OP's that he swapped over. Granted his is a 13' so there's probably and array of sensors that set them apart.
I could be totally off but my point being the OP should verify if he has the CKCP sensor or not to make sure all the components are working together in harmony since it's a bit of a Frankenstein.
@ Colorado-SHOBro that was my exact point from the beginning and appreciate you chiming in!  :)
The earlier version of the 2010MY Job 1 IIRC had a heated version PCV which worked as designed! As far as wiring goes! Z
68_GT
My car, valve covers, and PCV everything is the same there's no Frankenstein. The only thing changed is the shortblock which came with the composite valve covers and a different PVC that we didn't use. I wanted to keep the aluminum valance covers and not mess with getting a different quick connect tube for the different PVC nipple location.
I guess basically I need to perform the TSB for my model year ??
Sound right ??
68_GT
So I'll need a composite valve cover on the back side and keep my aluminum on the front side ??
