May 27, 2020, 07:42:16 am
Author Topic: Car leaking oil,smoking from exhaust oil Sep Fix!  (Read 8484 times)
Offline Colorado-SHOBro
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« on: January 16, 2018, 11:55:29 am »
Experienced an issue in the last few miles of my drive to work this morning.
it was 4 degrees this morning so i let the car warm up for 5 minutes and headed out. ran normally for most of the way but towards the end of the drive i could feel a slight stumble. i had the heater on and there was a VERY strong odor coming through. smelt like something burning but can't put my finger on exactly what.
parked the car and left it running and looked around the engine bay. car was smoking from the rear bank and there was oil around the back valve cover. oil pooled out of the rear BOV.(see pic).
let it sit for a few hours. went out and checked oil level, it was almost a quart low. started it again without any trouble then it began smoking out of the tail pipes pretty heavy. engine bay was still smoking and car was chugging a bit and idle bouncing.
i could also hear a burping/slurping sound coming from what sounded like the air box. pulled the cover and it was dry. coolant level normal.
no dtc
no misfires registered
what could it be?
blown rear turbo passing oil by the looks of the rear BOV?
popped cylinder?-prob not or i'd have misfires.
i'm all ears guys!
thanks
« Last Edit: January 17, 2018, 12:57:21 pm by ZSHO »
12.8@108 @ 6,000ft DA.
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
Re: Car leaking oil,smoking from exhaust oil Sep Fix!
« Reply #1 on: January 16, 2018, 12:36:29 pm »
https://www.youtube.com/watch?v=3oHJ-wIAPN4&feature=youtu.be
link to a video of smoke from exhaust. it got worse than this the longer i let it run
« Last Edit: January 17, 2018, 01:38:42 pm by ZSHO »
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
Re: Car leaking oil,smoking from exhaust oil Sep FIx!
« Reply #2 on: January 16, 2018, 12:38:12 pm »
Don't Drive it for the time being IMO!  Check the OCC lines to make sure there not frozen!
Check the PCV system Oil Sep! Check the Oil Cap ? Hopefully it doesn't look like pudding!  Check for Codes!  Z
« Last Edit: January 17, 2018, 01:38:17 pm by ZSHO »
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #3 on: January 16, 2018, 12:44:29 pm »
Check the PCV system Oil Sep!  Check the oil Cap  ? Z
yep i'm going to check the occ lines on my lunch. i guess a check valve could have failed too.
would any of that cause this though?
no i didn't look at the oil cap yet. ill do that too.
thanks for the suggestions
no codes present as of now.
« Last Edit: January 17, 2018, 01:39:46 pm by ZSHO »
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
« Reply #4 on: January 16, 2018, 12:58:42 pm »
I'm hoping its not the rear Turbo! especially the Oil Cap pudding of death!
It could be oil inside the crankcase!  Check the above mentioned!
I'm hoping you have Warranty!  Best of luck.  Z
« Last Edit: January 17, 2018, 01:41:06 pm by ZSHO »
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
Re: Car eating/leaking oil,smoking from exhaust.
« Reply #5 on: January 16, 2018, 01:03:15 pm »
Check the above mentioned! I'm hoping you have Warranty!  Best of luck.  Z
can you elaborate on the puddling of death? i'm not familiar.
i do have a warranty. will flash back to stock today and disconnect battery.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • New York SHO
  • Thank You
  • -Given: 1932
  • -Received: 4056
« Reply #6 on: January 16, 2018, 01:06:24 pm »
The worst case scenario is this!!  Dont mean to scare you!  Z
! No longer available
« Last Edit: January 16, 2018, 01:08:23 pm by ZSHO »
Offline pmezo33
  • Elite Member
  • Thank You
  • -Given: 81
  • -Received: 195
  • Ecobooster
« Reply #7 on: January 16, 2018, 01:15:27 pm »
Right off the bat, sounds to me like a bad oil separator.  They do go bad in these cars.  I'd pull it and see if there's excessive oil in there.
If there is, I'd replace that and the PCV valve and go from there.
Offline SHOdded
  • Forum Supporters
  • Elite Member
  • Beltsville, MD
  • Thank You
  • -Given: 12953
  • -Received: 4203
« Reply #8 on: January 16, 2018, 01:37:28 pm »
Def pull the hose off the rear turbo, a must in a situation like this.  Ford has already acknowledged the valve cover / pcv separator issue, fingers crossed it is just that ...
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #9 on: January 16, 2018, 01:40:51 pm »
pmezo may have hit it on the head. this is what I found. milky moisture at the separator. Oil cap and dipstick were totally clean.OCC lines seem clear and absolutely nothing came out of the catch can when I tried to drain it.
The only other thing I'm wondering is if a bad check valve at the OCC would cause this?
Offline pmezo33
  • Elite Member
  • Thank You
  • -Given: 81
  • -Received: 195
  • Ecobooster
« Reply #10 on: January 16, 2018, 02:03:18 pm »
That's moisture mixing with the oil.  Looks like you've isolated where the issue is assuming the rest of your oil doesn't look like that milky mess because then you'll have much bigger issues.
Change the oil separator and PCV, clean everything up, and you should (hopefully) be good to go.
Offline polskifacet
  • Elite Member
  • Chicago
  • Thank You
  • -Given: 114
  • -Received: 275
  • OCD Oils Changer
« Reply #11 on: January 16, 2018, 02:08:01 pm »
This is oddly similar to my oil smoking but mine was not to this extent. I think you can actually take apart the oil separator but the oring might go bad once you do. Wonder if it is actual oil sludge in the baffle. My OCC has been filling up with water in these low temps.
Offline polskifacet
  • Elite Member
  • Chicago
  • Thank You
  • -Given: 114
  • -Received: 275
  • OCD Oils Changer
« Reply #12 on: January 16, 2018, 02:17:20 pm »
Looks like the oil separator is gone after 2014 SHO models.
Offline Gray Brick
  • Sr. Member
  • Southern California
  • Thank You
  • -Given: 34
  • -Received: 108
  • Gray Brick
« Reply #13 on: January 16, 2018, 02:48:11 pm »
I changed my oil separator and PCV... oil/smoke issues went away.
2013 Ecoboost Ford Flex
  • Elite Member
  • Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #14 on: January 16, 2018, 03:33:29 pm »
did you have to replace your oil separator or was it a different issue?
* Featured Topics
* Recent Topics
Re: 802SHO 2010 Build
by 802SHO | Today at 06:17:39 am
Honestly that's not alot of $ for better flow vs our manifolds IM...
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
by 10sleeper | Today at 12:43:07 am
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
by 802SHO | May 26, 2020, 05:15:44 am
Re: EBPF Under New Ownership!
Re: EPP CAI
Re: Letís talk weight reduction?!
Re: Ford Recalls
Re: Brake Cooling Kit
Back to top
