September 17, 2019, 05:49:33 PM
Author Topic: Car leaking oil,smoking from exhaust oil Sep Fix!  (Read 5683 times)
Offline ecoboostsho
  • Forum Supporter!
  • Elite Member
  • : Minneapolis, MN
  • Thank You
  • -Given: 184
  • -Received: 239
  • Ecobooster
Re: Car leaking oil,smoking from exhaust oil Sep Fix!
« Reply #30 on: January 17, 2018, 12:56:49 PM »
Interesting!  So it sounds like it "can" be cleaned?  Or is that not recommended.  I'm guessing a new one can't cost that much.
2013 White SHO w/PP, Tune with AJP in progress, 3 Bar, 160T, Plugs...Mess with the Bull and you'll get the Horn. :)
Offline polskifacet
  • Elite Member
  • : Chicago
  • Thank You
  • -Given: 114
  • -Received: 272
  • OCD Oils Changer
« Reply #31 on: January 17, 2018, 01:21:14 PM »
It is between $60 and $80. I don't see why you can't just clean it. I was able to check if the internal check valve was holding so good to go. I'm sure some kind of schedule is much more effective then when you already have an issue. Clean it, it doesn't cost anything and effort level of 1.
AEM Dryflo drop in. PP Transmission Cooler and thermostat. 160 tstat, 3 bar map, plugs, AJP 93 Tune, PPE Catted Down Pipes, PTU Drain, Custom Polski Meth Injection, PP Shocks, H&R Springs.
Offline Colorado-SHOBro
  • Elite Member
  • : Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #32 on: January 17, 2018, 02:43:38 PM »
if your vehicle is low mileage(mine was @45k when it gave out) then cleaning at a regular interval certainly won't hurt. however, if yours fails like mine did the car is borderline undriveable and it could leave you stranded. then even worse your at the mercy of a local dealer having it in stock. in my case there was 1 dealer in the state that had one and it was  a 45min drive to get the part and was 95$ after tax.
ultimately i would recommend replacing the component then start a cleaning cycle.
12.8@108 @ 6,000ft DA.
  • Elite Member
  • : Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #33 on: January 18, 2018, 04:45:23 PM »
so yeah I just pulled this out of my intercooler after doing a few WOT pulls and noticing oil blown all over the engine bay from the rear BOV and wastegate mod. wow!
  • Elite Member
  • : Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #34 on: January 18, 2018, 04:50:29 PM »
and this was out of the catch can. obviously it was overworked since the oil separator took a crap.
Offline AJP turbo
  • SCT dealer and custom calibrator 3.5 ecoboost specialist
  • Elite Member
  • Thank You
  • -Given: 133
  • -Received: 1168
  • Log Warlock
« Reply #35 on: January 18, 2018, 04:56:37 PM »
So the failed pcv oil separator caused the intercooler to fill up with oil too!? Damn goes to show how important that piece is
On a side note makes me think how ridiculous it is to drill a hole in the intercooler to allow the condensated oil to escape which is really a symptom of another problem and not the root problem...not to mention an oily messy weep hole and potential loss of warranty.
Would never have known you had another problem if the intercooler was drilled😂😂😂
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11700
  • -Received: 3836
« Reply #36 on: January 18, 2018, 05:25:03 PM »
So you mean you should really drill down till you get to the real cause?  Seriously though, this would be great if it truly addresses the issue.  Pretty easy fix.  Maybe even the F150 would benefit.
  • Elite Member
  • : Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #37 on: January 18, 2018, 06:19:29 PM »
i hear ya brad. i would have never thought that failed component would result in such a pronounced issue. i guess i know why i was a quart low on oil now!!! seems to be a theme that when a part breaks on me it REALLY BREAKS! i don't think most cars would experience the oil consumption that i did on a failure.
  • Elite Member
  • : Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #38 on: January 18, 2018, 06:24:17 PM »
Here's the repair work order for reference from a few years ago which in my case replaced a leaky rear valve cover plus Oil Sep and PCV valve which was replaced under warranty as per TSB 14-0196 to correct the concern !
BTW found evidence of oil in the crankcase vent oil Separator and yes smoke was coming from exhaust tailpipe!  Z
2013+ TSB
http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79067.html#msg79067
2010-2012 TSB
https://www.ecoboostperformanceforum.com/index.php/topic,496.0.html
^ in regards to this i find it odd that the part that failed on my car is the same part # that is put in on the tsb and the same part# i replaced my bad one with. that tells me it's the same design so im not sure how it's a "fix" in the long term unless the 13+ originally came with a different oil separator than the one referenced in the TSB.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1643
  • -Received: 3573
« Reply #39 on: January 18, 2018, 07:07:15 PM »
2013+ TSB
2010-2012 TSB
There is no long-term or permanent FIX IMO!
There are unfortunately new revisions-supercession updated parts which can be downright confusing to say the least as parts goes! Dunno! But truly glad you were able to fix your car without a hitch and luck was on your side my friend.
What type of oil are you running ?
I would say staying on TOP of your vehicle maintenance aspect is crucial and goes a long way and should be treated under (severe conditions) as far as maintenance goes on this platform especially if tuned! just some food for thought!  Z
« Last Edit: January 18, 2018, 07:33:08 PM by ZSHO »
  • Elite Member
  • : Denver, CO
  • Thank You
  • -Given: 64
  • -Received: 312
« Reply #40 on: January 18, 2018, 07:37:11 PM »
Thanks Z i'm thankful it was a easy(albeit very inconvenient)fix.
I'm running amsoil 0w-30 and am relatively OCD with my maintenance schedule.
Right now my concern is getting the remnants of oil residue out of my intercooler. Need to find that thread from the guy that took off the drivers side turbo hose and used cleaning solution to wash things out.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1643
  • -Received: 3573
« Reply #41 on: January 18, 2018, 07:43:23 PM »
NP!  Z   :) CAC- HOW TO Courtesy of ShoBoat!
Best of luck.  Z
https://www.ecoboostperformanceforum.com/index.php/topic,3056.0.html
« Last Edit: January 18, 2018, 07:52:21 PM by ZSHO »
* Featured Topics
* Recent Topics
by Macgyver | Today at 04:46:08 PM
No kidding. My car weighs in at about 4280 ish with the entire interio...
Re: 2014 pp driveline in 2010 sho questions.
by SHOdded | Today at 11:54:51 AM
Just cap it!  Do go thru the shoforum thread....
Re: Splitter
by ZSHO | Today at 11:45:19 AM
It's unfortunately more of an issue with the odd dimensions than ...
Re: Ford Explorer
by ZSHO | Today at 11:40:53 AM
2020 Ford Explorer, Lincoln Aviator reportedly facing numerous QC issu...
Re: 9/15/19 New SHO ecoboost platform world record 11.214
by 802SHO | Today at 01:52:02 AM
Awesome Jordan!  I love that Dragy version of the first run! ...
Re: Dragy
by ridered74 | September 16, 2019, 08:32:35 PM
The track where I trapped 118 I have some suspicions about. LOL! Makes...
Re: Random thoughts for the day
by SHOdded | September 16, 2019, 04:29:12 PM
Save on K Source Towing Mirrors at RockAuto
by RockAuto | September 16, 2019, 10:00:45 AM
K Source, Inc. is offering RockAuto customers a 10% off instant rebate...
Re: rear shocks with performance package
by ZSHO | September 14, 2019, 01:58:11 PM
Warranty on the Monroe vs the Motorcraft Shocks.  Zhttps://www.m...
Re: 3 months free SiriusXM
by FearlessAZ | September 14, 2019, 06:36:30 AM
When I first tried this on my MKS, it said I just had a trial that end...
Re: Taurus sho trans upgrade
by Blackhawk | September 13, 2019, 07:12:41 AM
I'm sure Quaif would realize the limited number of people that wo...
Re: Rougher ride under lower RPMs and off throttle input
by avidmotion | September 12, 2019, 09:27:34 PM
When my ptu was going it made a weird whine sound varied by rpm.......
Re: DiCunzolo GEN2 Upgraded Trans Mount Review!
by avidmotion | September 12, 2019, 09:20:09 PM
Subscribe ...
Re: Welcome to the 11 Second Club!
by 802SHO | September 12, 2019, 05:26:32 AM
Thanks for the link Z!  My new personal best time and trap speed ...
Re: PD SHO knocks off a Chevy 6.2
by 802SHO | September 11, 2019, 01:53:45 AM
I love how moms navigator was thrown into the mix!  Lmao!  N...
Back to top
