1/4 Mile Times Stock 2010-2014 SHO
Started by ROCOB, August 06, 2013, 08:47:13 PM
ROCOB
As the title states, I would like to hear about the "real world" times from other members.  I am curious how my car stacks up with others.
Below is my first outing.
TEMP/HUMIDITY 81 DEGREES/83%
TIME                 2203                2251
R/T                    0.527               .368
60'                     2.171               2.158
330'                   5.989               5.981
1/8 MILE           9.136               9.131
1/8 MPH           81.04               81.01
1000'                 11.851             11.848
1/4 MILE ET      14.122             14.123
1/4 MPH           99.46               99.35
Moderators, if I have posted this in the wrong place please move it.
Thanks,
ROCOB
2013 402A PP
White Platinum Metallic
K&N Flat Panel Filter, otherwise stock
Here is my bone stock at 97deg vs a 5.7L charger(on the left) and tune only vs a SRT8 Charger at 95deg. Not bad being that hot in " HOT ATLANTA"  :popcorn:
2011 FORD SHO vs 5.7L charger
2011 FORD SHO vs SRT8 Charger
R/T                  .5567
60'                   2.1769
330'                 6.0038
ET@594'.          8.6289
1/8 MILE          9.2206
1/8 MPH           76.04
1000'               11.9061
1/4 MILE ET      14.1966
1/4 MPH            100.05
I made 11 passes that evening.
Every other pass was between 14.22-14.29 @99.04-99.84mph
About 93 degrees, pretty humid, full tank of gas, baby seat in back, spare tire still in trunk.
It was kind of a spur of the moment decision to go
ROCOB
Thanks for the replies.  I ran at Atlanta Dragway with my usual gear in the car and tipped the scales @ 4515 lbs.   :(  (including driver)
I am quite pleased with the performance of my car, I need to work on my driving skill now ;D
2013 402A PP
Quote from: glock-coma on August 06, 2013, 10:07:32 PM
R/T                  .5567
60'                   2.1769
330'                 6.0038
ET@594'.          8.6289
1/8 MILE          9.2206
1/8 MPH           76.04
1000'               11.9061
1/4 MILE ET      14.1966
1/4 MPH            100.05
Not bad for your first runs...need to work on the reaction time.  My tip is to smash the gas when you see the last yellow light come on, never wait to see the green.  Also, if you know anyone who has driving experience if they watch you, most will be willing to give you tips.  Hopefully you left the car in D, since it seems that yields the best times.  But still not bad for 93 degree weather.
Quote from: mjhpadi on August 07, 2013, 01:58:39 PM
R/T                  .5567
60'                   2.1769
330'                 6.0038
ET@594'.          8.6289
1/8 MILE          9.2206
1/8 MPH           76.04
1000'               11.9061
1/4 MILE ET      14.1966
1/4 MPH            100.05
Thx for the advise. I can use all I can get.
This  was the first time i ever actually raced at the track. Most of my other reaction times     were in the .350 range. My best was .107 I was trying to keep an eye on the revs.
It seemed to like 2000-2400 range
Quote from: ROCOB on August 07, 2013, 10:48:26 AM
ROCOB  WHAT PARK of ATLANTA DO YOU LIVE IN? You know I live in ATLANTA too.
Shoman, you need to meet up with these guys and give them some driving tips..I'm betting with your track experience you could impart some pretty valuable knowledge to them on achieving the best track times!
Quote from: mjhpadi on August 07, 2013, 11:03:14 PM
I PM ROCOB and maybe me and Airportguy770 can meet up.
Night Hawk
#9
R/T   .204            New England Dragway 10/22/2011@0944am
60'    2.086
330   5.794
1/8   8.906
mph  78.99
1000  11.570
1/4   13.799
MPH  101.02   all 4558lbs of her, with me in it lol
2017 Fusion Sport
GFB DivValve/165* Thermo
K&N Panel/CFM Breather
Ult Perf Int Garrett Core/MKZ oil cooler
FMS 70mm TB/ NGK .026/LMS V6 93
darreli
R/T                  .5567
60'                   2.1769
330'                 6.0038
ET@594'.          8.6289
1/8 MILE          9.2206
1/8 MPH           76.04
1000'               11.9061
1/4 MILE ET      14.1966
1/4 MPH            100.05
Reaction time doesn't matter on your ET..unless you're actually racing. Your 60ft could probably be improved on. To correct that just barely turn on the second set of lights when staging..hold the brake bring the revs up (probably around 1800 on stock) then smash the gas on the last yellow and slip the brake
Quote from: shoman04 on August 08, 2013, 05:14:20 AM
WELL I HAD TO SHOW ROCOB HOW TO USE ALL THE THINKS TOLD HIM.LOL This the 2nd or 3rd round of "13.99 and faster bracket racing" ROCOB did very good. I made it to semi-final (my 1st time bracket racing) I should have change my dial-in from 12.28sec to 12.31 because my best of the night was 12.33sec. But I did good for 1st time.
Rocob will not dance on me
bracketracing 12.33 run SHO vs LS3 CAPRICE
EcoBrick Bob
Yeah!!! You done Gooood!   It's addictive... almost better than sex.....almost....
Naples, FL & Clear Lake, IA
dmharvey79
Congrats, not a bad first time! work on the reaction time/60'.   What EBB said, but capitalize "almost"  LOL
