Dash Cam for Track!!
Started by ZSHO, September 26, 2017, 08:59:42 AM
I was looking for a basic Dash Cam primarily for Track use and came across this Vantrue X1 Car Dash Cam - Full HD 1080P 1920x1080 Dash Cam 170° Wide Angle 2.7" LCD In Car Dashboard Camera DVR Video Recorder with G-Sensor, Parking Mode, HDR & Super Night Vision for $89.99.
I know there are bigger and better cams out there such as the GO-PRO but i'm not looking to climb a mountain or dive under water just something practical for everyday use.
Thoughts,suggestions would be greatly appreciated.  Z
https://www.amazon.com/Vantrue-X1-Car-Dash-Cam/dp/B01IHLZIU0/ref=sr_1_4?s=electronics&rps=1&ie=UTF8&qid=1506429704&sr=1-4&keywords=dash+camera+for+cars&refinements=p_85%3A2470955011%2Cp_72%3A1248879011%2Cp_n_condition-type%3A2224371011%2Cp_36%3A1253505011
A general use dashcam is KDLinks as shown in this review
https://youtu.be/TEUe2p1rsDI
irondoor19
Make sure you check with the track prior to mounting anything in the Window
I learned the hard way during a major points race "test and tune" it went like this
I had my Ipad in the window on a suction mount, Got flagged over at the shutdown
end by the officials, the response WAS:
"Get that dam thing out of the window, MAN this dam thing is fast, what are you running Torque?"
Primalzer
Been running a G1W-C for a few years now. Got the rear-view mirror mount. On my previous car, I stuck a wiring harness kit up in the headliner and spliced into some permanently live 12V wires. For the Flex, I ran the extra long 12V adapter wire, tucked into the headliner, tucked into the A-pillar, and then Velcro strapped up under the dash to the passenger footwell 12V adapter location. Made for a quick, easy, clean, and cheap solution.
2011 Ford Flex Limited EcoBoost
-2013+ PP SHO front brake conversion
lamrith
Quote from: irondoor19 on September 26, 2017, 10:57:44 AM
Yeah big unit like Ipad they always tweak about.  I think a unit like Z shows, mounted up next to mirror on passenger side might not even get noticed.  That or mount a gopro to your helmet...  The concern is something fling around the cabin if you have a wreck.
