2.5" you can slip over stock, and will have to widen the stock 2.25" a bit to make a smooth transition and proper seal. You can also buy an appropriate 2.25" Xpipe, intlets will be a bit larger than that, so that you don't need any resizing of the stock stuff. With an X and flowmasters my car was pretty friken loud, and with downpipes it sounded like a monster. Both cases it could be heard from a few blocks away. You will likely get a bit more drone with the X than the stock setup.
